[Qgis-user] An issue with DEM terrain models
Giacomo Fontanelli
giacomofontanelli76 at gmail.com
Thu Mar 9 08:13:37 PST 2017
Hi everybody
I'm using a SRTM 4 (Geotiff, Int16 - Sixteen bit signed integer) and QGIS
2.18.1.
I tried to produce a slope map using Raster > analysis > DEM (terrain
model).
In case I would like to have degrees as output i obtain a map with values
from 89.5 to 90 degrees only, so almost impossible to classify.
In case I flag the option"Slope expressed as percent" I obtain a map with
more pixel values, but the slope is expressd with numbers from 0 to1971690.
What's the problem?
Thank you
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170309/c68da4bf/attachment.html>
