[Qgis-user] An issue with DEM terrain models
Carlos Cerdán
sig.upagu at gmail.com
Thu Mar 9 09:14:47 PST 2017
Hi Giacomo
Perhaps the SRC of your DEM is ESPG4326 (lat-long) if so, vertical units
are meters and horizontal units are degrees, then the relation between
vertical and horizontal units is 111111, and you must put that value in the
"scale" option. It is because 90° = 10'000,000 m (one cuarter of meridian).
Saludos
Carlos
2017-03-09 11:13 GMT-05:00 Giacomo Fontanelli <giacomofontanelli76 at gmail.com
> Hi everybody
> I'm using a SRTM 4 (Geotiff, Int16 - Sixteen bit signed integer) and QGIS
> 2.18.1.
> I tried to produce a slope map using Raster > analysis > DEM (terrain
> model).
> In case I would like to have degrees as output i obtain a map with values
> from 89.5 to 90 degrees only, so almost impossible to classify.
> In case I flag the option"Slope expressed as percent" I obtain a map with
> more pixel values, but the slope is expressd with numbers from 0 to1971690.
> What's the problem?
> Thank you
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170309/c639188f/attachment.html>
