[Qgis-user] How to merge layers without a work-around?
Tobias Wendorff tobias.wendorff at tu-dortmund.de
Thu Mar 9 12:33:15 PST 2017
Hi there.
Is there any way to merge two scratch layers? Even big ones...
I've tried the one in SAGA, in MMQGIS and the native QGIS one.
SAGA's executable crashed after 5 minutes, but QGIS was alive.
MMQGIS also throw out an error after some minutes of processing.
And the native one tells me:
"global name 'dataobjects' is not defined See log for more details"
Actually, this sems to be a bug in "Merge.py":
"layer = dataobjects.getObjectFromUri(layerSource)"
I've ended up selection all elements and copy & paste them to a
new layer. But there's also an unexpected event: even when you've
selected all the elements in two layers, you can copy the layer,
which is currently selected in the layers panel. Is this a bug?
How do you merge layers? Sure, there's ogr2ogr - but I want
to use QGIS. Of course, I'm merging layers with the same
geometry only (f.e. points).
Best regards,
Tobias
