[Qgis-user] Embed layers and groups
Laurence Béchet
bechet.laurence at gmail.com
Thu Mar 9 12:07:08 PST 2017
Thanks Andrea. I'll create them.
These are not big issues and easy to work around as a user.
I agree with you this new embedded layers feature is awesome and for
little mapping projects like Ark in the Park they are very useful as I
have my layout already ready and just need to add what i want to plots:
bird territories or past control results or ..... Also if something in
the layout changes (new track, pest control grid altered) I only need to
modify the 'master' map and it is propagated to all the other maps.
Worth a try!
Kind regards
Laurence
ARK IN THE PARK Volunteer Co-Ordinator
Cascades Ranger Station
Falls Road, Waitakere
Phone: (09) 810 7014
www.arkinthepark.org.nz www.forestandbird.org.nz
On 9/03/2017 10:58 p.m., Neumann, Andreas wrote:
> Hi Laurence,
> I can confirm both issues.
> Embedded groups show empty (without the layers, only the groups are
> displayed) in QGIS 3 and they are stylable in the styling dock in 2.18
> when they shouldn't be stylable.
> However, if your restyle embedded layers in the styling dock, they
> are, of course not saved back to the original layers. This would be
> dangerous and probably unwanted in most cases.
> The styling dock is fairly new and probably the devs where not aware
> about the embedded layers feature.
> Can you please issue bug reports for both issues?
> Embedded layers and groups are probably not used that much in the
> wild, but I find them incredibly useful. It is one of my favourite
> QGIS feature and saves you tons of work if you can re-use background
> layers from other projects, while still being able to identify these
> layers or snap to them.
> Unfortunately, many users and devs are not aware of this feature and
> it doesn't get much attention.
> Thanks,
> Andreas
> On 2017-03-08 22:10, Laurence Béchet wrote:
>> Hi,
>> I'm trying to use the embed layers and groups feature.
>> I'm running on Windows8 pro 64bits.
>> I have created a new project and I am loading a group of layers which
>> are my background (streams, lakes, etc ..) in a main project.
>> QGIS 2.18.4 QGIS code revision 59c1d21:
>> I get the group loaded nicely. As expected, I cannot access the
>> properties if I double click on the layer. However, if I have the
>> layer styling panel open, I can change the style ... I have not
>> checked what happens to the main project. Question 1: Is this normal?
>> QGIS version 2.99.0-Master QGIS code revision 5a543e4:
>> The group appears in the layers panel but none of the layers are
>> displayed. Question 2: Is this normal?
>> Kind regards
>> Laurence Bechet
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170310/5cf7534b/attachment.html>
