[Qgis-user] Embed layers and groups
DelazJ delazj at gmail.com
Fri Mar 10 03:05:02 PST 2017
Actually it's not a new feature. Has been there since.... (available in 1.8
documentation
http://docs.qgis.org/1.8/en/docs/user_manual/introduction/general_tools.html#nesting-projects
And as you can see, the documentation has neither been improved since.
Given your discussion I tried to put some highlights on the feature and any
review is welcome https://github.com/qgis/QGIS-Documentation/issues/1748
I'm more a default style user than an embedded layer one so if I miss some
advantages in this feature please, let me know.
Laurence, I didn't check if you had reported the issues yet, otherwise I
think removal of some items can be added:
- Layer menu --> Labeling
- when right-clicking an embedded layer --> Style.
Given that the Layer Properties dialog is not availbale, there are some
actions like "Set Scale visibility of layer", "Set layer CRS", "Filter"
(that belong to the Properties --> General menu) that make me fail to
understand the real scope of an embedded layer. Are they supposed to be
grayed too or not? What kind of changes are really allowed on such a layer
or what is really kept from the "source" file?
Thanks,
Harrissou
2017-03-09 21:07 GMT+01:00 Laurence Béchet <bechet.laurence at gmail.com>:
> Thanks Andrea. I'll create them.
> These are not big issues and easy to work around as a user.
> I agree with you this new embedded layers feature is awesome and for
> little mapping projects like Ark in the Park they are very useful as I have
> my layout already ready and just need to add what i want to plots: bird
> territories or past control results or ..... Also if something in the
> layout changes (new track, pest control grid altered) I only need to modify
> the 'master' map and it is propagated to all the other maps. Worth a try!
> Kind regards
> Laurence
> ARK IN THE PARK Volunteer Co-Ordinator
> Cascades Ranger Station
> Falls Road, Waitakere
> Phone:  (09) 810 7014
> www.arkinthepark.org.nz  www.forestandbird.org.nz
> On 9/03/2017 10:58 p.m., Neumann, Andreas wrote:
> Hi Laurence,
> I can confirm both issues.
> Embedded groups show empty (without the layers, only the groups are
> displayed) in QGIS 3 and they are stylable in the styling dock in 2.18 when
> they shouldn't be stylable.
> However, if your restyle embedded layers in the styling dock, they are, of
> course not saved back to the original layers. This would be dangerous and
> probably unwanted in most cases.
> The styling dock is fairly new and probably the devs where not aware about
> the embedded layers feature.
> Can you please issue bug reports for both issues?
> Embedded layers and groups are probably not used that much in the wild,
> but I find them incredibly useful. It is one of my favourite QGIS feature
> and saves you tons of work if you can re-use background layers from other
> projects, while still being able to identify these layers or snap to them.
> Unfortunately, many users and devs are not aware of this feature and it
> doesn't get much attention.
> Thanks,
> Andreas
> On 2017-03-08 22:10, Laurence Béchet wrote:
> Hi,
> I'm trying to use the embed layers and groups feature.
> I'm running on Windows8 pro 64bits.
> I have created a new project and I am loading a group of layers which are
> my background (streams, lakes, etc ..) in a main project.
> QGIS 2.18.4 QGIS code revision 59c1d21:
> I get the group loaded nicely. As expected, I cannot access the properties
> if I double click on the layer. However, if I have the layer styling panel
> open, I can change the style ... I have not checked what happens to the
> main project.  Question 1: Is this normal?
> QGIS version 2.99.0-Master QGIS code revision 5a543e4:
> The group appears in the layers panel but none of the layers are
> displayed. Question 2: Is this normal?
> Kind regards
> Laurence Bechet
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170310/8b6b9058/attachment.html>
