[Qgis-user] GEO-REFERENCER not working
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Tue Mar 14 07:07:59 PDT 2017
Did you manually remove all .qgis2 folders for all the users in the computers? If you have have 3 users , you have 3 .qgis2 folders. Did you destroy the registry keys?
You talk about a full uninstall, what procedure did you use? You must have something lying around giving you problems.
Nicolas
> Le 14 mars 2017 à 07:27, civil142 [via OSGeo.org] <ml-node+s1560n5312222h43 at n6.nabble.com> a écrit :
> Hi Nicolas,
> It was working originally and I used it a lot. I have uninstalled QGIS several times and replaced with several subsequent versions but it still remains broken. When I click the geo referencer button, nothing happens.
> I have to use QGIS on a new machine to use the geo reference function. You would think that a full uninstall and a reinstall would fix any such issues, however this persists.
> Kind regards,
> Ian
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/GEO-REFERENCER-not-working-tp5271041p5312222.html
> To start a new topic under QGIS - User, email ml-node+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from QGIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/GEO-REFERENCER-not-working-tp5271041p5312256.html
Sent from the QGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170314/e92efe54/attachment.html>
