[Qgis-user] Processing Toolbox Grass Error on executing algorithm
Marco Lechner - FOSSGIS e.V.
marco.lechner at fossgis.de
Sat Mar 18 08:35:16 PDT 2017
this is a known (and already fixed) issue:
https://hub.qgis.org/issues/16110
As a workaround you can set a symlink from grass72 to grass70 as
described here until you get a patched update:
http://gis.stackexchange.com/questions/225464/cannot-run-grass-algorithms-in-qgis-2-18-on-ubuntu-16-04
Best regards
Marco
Am 18.03.2017 um 14:30 schrieb Sindile Bidla:
> I am running Ubuntu 16.04 64bit,
> QGIS version
> 2.99.0-Master
> QGIS code revision
> 921a0c7 <https://github.com/qgis/QGIS/commit/921a0c7>
> Compiled against Qt
> 5.5.1
> Running against Qt
> 5.5.1
> Compiled against GDAL/OGR
> 2.1.2
> Running against GDAL/OGR
> 2.1.2
> Compiled against GEOS
> 3.5.1-CAPI-1.9.1
> Running against GEOS
> 3.5.1-CAPI-1.9.1 r4246
> PostgreSQL Client Version
> 9.5.2
> SpatiaLite Version
> 4.3.0a
> QWT Version
> 6.1.2
> PROJ.4 Version
> 492
> QScintilla2 Version
> 2.9.1
> This copy of QGIS writes debugging output.
> Trying to run any of the Grass tools on the Processing Toolbox, I get
> the following error:
> This algorithm cannot be run :-(
> It seems that GRASS GIS 7 is not correctly installed and configured in
> your system. Please install it before running GRASS GIS 7 algorithms.
> I have Grass 7.2 installed
> grass72: /usr/bin/grass72 /usr/lib/grass72 /usr/share/grass72
> /usr/share/man/man1/grass72.1.gz
> Clicking enable additional providers, I get the following stack trace
> error
> An error has occurred while executing Python code:
> TypeError: __init__() takes 1 positional argument but 2 were given
> Traceback (most recent call last): File
> "/usr/share/qgis/python/plugins/processing/gui/ProcessingToolbox.py",
> line 77, in openSettings dlg = ConfigDialog(self) TypeError:
> Python version: 3.5.2 (default, Nov 17 2016, 17:05:23) [GCC 5.4.0
> 20160609]
> QGIS version: 2.99.0-Master Master, 921a0c7
> Python Path:
> * /usr/share/qgis/python/plugins/processing
> * /home/user1/.qgis3/python
> * /home/user1/.qgis3/python/plugins
> * /usr/lib/python35.zip
> * /usr/lib/python3.5
> * /usr/lib/python3.5/plat-x86_64-linux-gnu
> * /usr/lib/python3.5/lib-dynload
> * /usr/local/lib/python3.5/dist-packages
> * /usr/lib/python3/dist-packages
> * /home/user1/.qgis3//python
> * /home/user1/spatial_data
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170318/ebe842b1/attachment.html>
