[Qgis-user] Processing Toolbox Grass Error on executing algorithm
Sindile Bidla
sindile.bidla at gmail.com
Sat Mar 18 06:30:36 PDT 2017
I am running Ubuntu 16.04 64bit,
QGIS version
2.99.0-Master
QGIS code revision
921a0c7 <https://github.com/qgis/QGIS/commit/921a0c7>
Compiled against Qt
5.5.1
Running against Qt
5.5.1
Compiled against GDAL/OGR
2.1.2
Running against GDAL/OGR
2.1.2
Compiled against GEOS
3.5.1-CAPI-1.9.1
Running against GEOS
3.5.1-CAPI-1.9.1 r4246
PostgreSQL Client Version
9.5.2
SpatiaLite Version
4.3.0a
QWT Version
6.1.2
PROJ.4 Version
492
QScintilla2 Version
2.9.1
This copy of QGIS writes debugging output.
Trying to run any of the Grass tools on the Processing Toolbox, I get the
following error:
This algorithm cannot be run :-(
It seems that GRASS GIS 7 is not correctly installed and configured in your
system. Please install it before running GRASS GIS 7 algorithms.
I have Grass 7.2 installed
grass72: /usr/bin/grass72 /usr/lib/grass72 /usr/share/grass72
/usr/share/man/man1/grass72.1.gz
Clicking enable additional providers, I get the following stack trace error
An error has occurred while executing Python code:
TypeError: __init__() takes 1 positional argument but 2 were given
File "/usr/share/qgis/python/plugins/processing/gui/ProcessingToolbox.py",
line 77, in openSettings
dlg = ConfigDialog(self)
Python version: 3.5.2 (default, Nov 17 2016, 17:05:23) [GCC 5.4.0 20160609]
QGIS version: 2.99.0-Master Master, 921a0c7
Python Path:
- /usr/share/qgis/python/plugins/processing
- /home/user1/.qgis3/python
- /home/user1/.qgis3/python/plugins
- /usr/lib/python35.zip
- /usr/lib/python3.5
- /usr/lib/python3.5/plat-x86_64-linux-gnu
- /usr/lib/python3.5/lib-dynload
- /usr/local/lib/python3.5/dist-packages
- /usr/lib/python3/dist-packages
- /home/user1/.qgis3//python
- /home/user1/spatial_data
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170318/7a9ce8d6/attachment.html>
