[Qgis-user] How to reproject maps of world grasslands
Paulo van Breugel
p.vanbreugel at gmail.com
Mon Mar 20 07:14:15 PDT 2017
On 20-03-17 13:30, Martin wrote:
> Thank you very much. I tried this suggestion and it works perfectly!
> Forgive my ignorance, but how did you know that '+proj=igh' would
> produce the correct result? I understand that igh means Interrupted
> Goode Homolosine, but where did you find this information (this is for
> my education)?
See the link Raymond gave you, http://proj4.org/projections/igh.html.
> I am going to write to WWF and suggest that they make the grasslands
> shape file available in WGS84 (i.e. EPSG 4326), as I would like to
> direct others to it without the need for providing an explanation of
> how to transform the data.
Yes, that is a good idea.
> I discovered that ArcGIS understands the Interrupted Goode Homolosine
> CRS. A friend with ArcGIS has now converted it to EPSG 4326 for me and
> this also works fine and produces the same result as your excellent
> suggestion.
> Ciao, Martin
> On 20/03/17 07:54, Paulo van Breugel wrote:
>> Using the definition on the proj4 page, you can define a custom CRS
>> (settings --> custom crs). Just fill in under parameters '+proj=igh'.
>> I just tried and it gives a good match
>> Note that this grassland layer is based on the terrestrial
>> ecoregional map of WWF [1]. If you over overlay that on your
>> grassland layer, using for the latter the Interrupted Goode
>> Homolosine CRS, you see they will overlap perfectly. You could in
>> fact easily recreate the map using the ecoregional map.
>> Cheers,
>> Paulo
>> [1]https://www.worldwildlife.org/publications/terrestrial-ecoregions-of-the-world
>> On 20-03-17 07:46, Martin wrote:
>>> Many thanks Raymond: that is helpful. Now at least I know what the
>>> projection is! As QGIS has so many projections it never occurred to
>>> me that there may be one that it didn't include. I will now see if
>>> there is some other way - outside QGIS perhaps? - to convert this
>>> projection into something more friendly (so to speak).
>>> Martin
>>> On 19/03/17 21:30, Raymond Nijssen wrote:
>>>> Hi Martin,
>>>> Sorry, I cannot really help you.
>>>> Your data seems to be in the (quite odd for distributing data)
>>>> projection:
>>>> https://en.wikipedia.org/wiki/Goode_homolosine_projection
>>>> And it is not recognized by qgis.
>>>> Proj4 seems to know it though:
>>>> And I found this:
>>>> http://gis.stackexchange.com/questions/17263/is-it-possible-to-use-the-goode-homolosine-projection-in-qgis
>>>> Hope it helps (a bit),
>>>> Raymond
>>>> On 19-03-17 20:49, Martin wrote:
>>>>> Hello folks!
>>>>> I would like to plot a simple map of the WWF World Grassland Types
>>>>> (the
>>>>> shape file is available at
>>>>> https://www.worldwildlife.org/publications/world-grassland-types
>>>>> It is in an unusual projection. The .prj file is:
>>>>> PROJCS["World_Goode_Homolosine_Land",GEOGCS["GCS_WGS_1984",DATUM
>>>>> ["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM
>>>>> "Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION
>>>>> ["Goode_Homolosine"],PARAMETER["False_Easting",0.0],PARAMETER
>>>>> ["False_Northing",0.0],PARAMETER["Central_Meridian",0.0],PARAMETER
>>>>> ["Option",1.0],UNIT["Meter",1.0]]
>>>>> The map does not include the outline countries of the world and
>>>>> therefore I would like to add these (perhaps the NaturalEarth 110
>>>>> million scale country shape file, which is in WGS84).
>>>>> However, I cannot figure out how to align the grassland layer and the
>>>>> 110 million NaturalEarth layer. As I understand it, I should use
>>>>> Save As
>>>>> to reproject the grassland shape file with a new CRS (perhaps
>>>>> Mercator).
>>>>> With Enable on the fly CRS transformation enabled I should then be
>>>>> able
>>>>> to put the two shape files together - but I am darned if I can obtain
>>>>> anything sensible: I cannot get the two layers to align in any way.
>>>>> With grateful thanks for any help, Martin
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170320/265e2969/attachment.html>
