[Qgis-user] QGIS 2.18 crashes on style by category
Richard Duivenvoorde rdmailings at duif.net
Thu Mar 23 01:30:34 PDT 2017
On 22-03-17 19:05, Jonathan Webb wrote:
> Hello,
> Linux Mint 17.2
> Eventually managed to reinstall QGIS, upgrading from 2.16 to 2.18.
> Was working OKfor about a day (apart from missing geoprocessing/geometry
> & analysis tools now mostly resolved), then started crashing out instantly.
> I think I've tracked it down to applying a categorised style to a
> polyline shapefile, some of the categories are turned off so they don't
> display. I've been digitising against this on & off for a day & it was
> OK, then suddenly started crashing.
> In case it's relevant, my GRASS7 plugins aren't working either.
Hi Jonathan,
can you try this on another computer?
and if that combination of data + styles still crashes there, I think
you should create an issue in the bugtracker and add as much info as
possible to it (versions you use 2.18-which?) and preferebly the dataset
(or a small portion of it) that causes the trouble.
Regards,
