[Qgis-user] QGIS 2.18 crashes on style by category
Jonathan Webb
jonathan at jwebbgis.co.uk
Thu Mar 23 10:11:52 PDT 2017
Hi Jorge,
I uninstalled all my plugins & that project won't even open now.
GDB report is:
$ gdb -ex=r --args /usr/bin/qgis.bin
GNU gdb (Ubuntu 7.7.1-0ubuntu5~14.04.2) 7.7.1
Copyright (C) 2014 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "x86_64-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from /usr/bin/qgis.bin...(no debugging symbols
found)...done.
Starting program: /usr/bin/qgis.bin
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Warning: loading of qgis translation failed
[/usr/share/qgis/i18n//qgis_en_GB]
Warning: loading of qt translation failed
[/usr/share/qt4/translations/qt_en_GB]
[New Thread 0x7fffcd875700 (LWP 11457)]
[New Thread 0x7fffc7fff700 (LWP 11458)]
[New Thread 0x7fffc75cf700 (LWP 11459)]
[New Thread 0x7fffc6dce700 (LWP 11460)]
Warning: QCss::Parser - Failed to load file "/style.qss"
QInotifyFileSystemWatcherEngine::addPaths: inotify_add_watch failed: No
such file or directory
[New Thread 0x7fffc65cd700 (LWP 11462)]
Warning: QFileSystemWatcher: failed to add paths:
/home/jonathan/.qgis2//project_templates
[New Thread 0x7fffc5dcc700 (LWP 11463)]
[New Thread 0x7fffc55cb700 (LWP 11464)]
Warning: QLayout: Attempting to add QLayout "" to QgsPanelWidgetStack
"mWidgetStack", which already has a layout
[New Thread 0x7fff5e2e6700 (LWP 11492)]
[New Thread 0x7fff5dae5700 (LWP 11527)]
[New Thread 0x7fff5d2e4700 (LWP 11528)]
[New Thread 0x7fff5cae3700 (LWP 11529)]
Warning: QPainter::begin: A paint device can only be painted by one
painter at a time.
Warning: QPainter::setRenderHint: Painter must be active to set
rendering hints
Warning: QPainter::setBrush: Painter not active
Warning: QPainter::setPen: Painter not active
Warning: QPainter::translate: Painter not active
Warning: QPainter::drawPath: Painter not active
Warning: QPainter::end: Painter not active, aborted
painter at a time.
rendering hints
[Thread 0x7fff5dae5700 (LWP 11527) exited]
[Thread 0x7fff5e2e6700 (LWP 11492) exited]
[Thread 0x7fff5d2e4700 (LWP 11528) exited]
me killed it as unresponsive
[Thread 0x7fff5cae3700 (LWP 11529) exited]
[Thread 0x7fffc55cb700 (LWP 11464) exited]
[Thread 0x7fffc65cd700 (LWP 11462) exited]
[Thread 0x7fffc6dce700 (LWP 11460) exited]
[Thread 0x7fffcd875700 (LWP 11457) exited]
[Thread 0x7fffc75cf700 (LWP 11459) exited]
[Thread 0x7fffc7fff700 (LWP 11458) exited]
[Thread 0x7fffc5dcc700 (LWP 11463) exited]
Program terminated with signal SIGKILL, Killed.
The program no longer exists.
This doesn't tell me much
I've been advised to file a bug report, so am waiting for an OSGEO account.
Cheers
jonathan
Jonathan Webb
Freelance GIS Specialist
07941 921905
http://www.jwebbgis.co.uk
http://uk.linkedin.com/in/jwebbgis
On 22/03/17 19:15, Jorge Gustavo Rocha wrote:
> Hi Jonathan,
> Às 18:56 de 22-03-2017, Jonathan Webb escreveu:
>> Hi Jorge,
>> Thanks,
>> 1. Not sure you mean "without anything else installed"? I moved the
>> backup ~qgs file & still crashes.
> I meant without any plugin installed. Plugins might cause problems when
> changing QGIS version.
> Try to start with gdb just to see the reason for crashing. On the terminal:
> Regards,
> Jorge
>> 2 I used ppa:ubuntugis/ubuntugis-unstable
>> 2.1
>> $ dpkg -l | grep qgis | awk '{print $2, $3}'
>> libqgis-analysis2.18.4 1:2.18.4+20trusty-ubuntugis
>> libqgis-app2.18.4 1:2.18.4+20trusty-ubuntugis
>> libqgis-core2.18.4 1:2.18.4+20trusty-ubuntugis
>> libqgis-customwidgets 1:2.18.4+20trusty-ubuntugis
>> libqgis-gui2.18.4 1:2.18.4+20trusty-ubuntugis
>> libqgis-networkanalysis2.18.4 1:2.18.4+20trusty-ubuntugis
>> libqgis-server2.18.4 1:2.18.4+20trusty-ubuntugis
>> libqgisgrass7-2.18.4 1:2.18.4+20trusty-ubuntugis
>> libqgispython2.18.4 1:2.18.4+20trusty-ubuntugis
>> python-qgis 1:2.18.4+20trusty-ubuntugis
>> python-qgis-common 1:2.18.4+20trusty-ubuntugis
>> qgis-plugin-grass 1:2.18.4+20trusty-ubuntugis
>> qgis-plugin-grass-common 1:2.18.4+20trusty-ubuntugis
>> qgis-provider-grass 1:2.18.4+20trusty-ubuntugis
>> qgis-providers 1:2.18.4+20trusty-ubuntugis
>> qgis-providers-common 1:2.18.4+20trusty-ubuntugis
>> Cheers
>> Jonathan
>> Jonathan Webb
>> 07941 921905
>> On 22/03/17 18:35, Jorge Gustavo Rocha wrote:
>>> Hi Jonathan,
>>> 1. Try to remove (backup first) your ~/.qgis2 folder, to start qgis
>>> without anything else installed.
>>> 2. Which repository did you use to install QGIS?
>>> 2.1 Can you provide a list of all qgis related packages, to check if
>>> there are any package conflicts or packages coming from different
>>> repositories/version?
>>> Can you try something like:
>>> On my system, I've installed QGIS from ubuntugis respository. The result
>>> of the above command is:
>>> libqgis-analysis2.18.4 1:2.18.4+24xenial-ubuntugis
>>> libqgis-app2.18.4 1:2.18.4+24xenial-ubuntugis
>>> libqgis-core2.18.4 1:2.18.4+24xenial-ubuntugis
>>> libqgis-customwidgets 1:2.18.4+24xenial-ubuntugis
>>> libqgis-gui2.18.4 1:2.18.4+24xenial-ubuntugis
>>> libqgis-networkanalysis2.18.4 1:2.18.4+24xenial-ubuntugis
>>> libqgis-server2.18.4 1:2.18.4+24xenial-ubuntugis
>>> libqgisgrass7-2.18.4 1:2.18.4+24xenial-ubuntugis
>>> libqgispython2.18.4 1:2.18.4+24xenial-ubuntugis
>>> python-qgis 1:2.18.4+24xenial-ubuntugis
>>> python-qgis-common 1:2.18.4+24xenial-ubuntugis
>>> qgis-plugin-globe 1:2.18.4+24xenial-ubuntugis
>>> qgis-plugin-globe-common 1:2.18.4+24xenial-ubuntugis
>>> qgis-plugin-grass 1:2.18.4+24xenial-ubuntugis
>>> qgis-plugin-grass-common 1:2.18.4+24xenial-ubuntugis
>>> qgis-provider-grass 1:2.18.4+24xenial-ubuntugis
>>> qgis-providers 1:2.18.4+24xenial-ubuntugis
>>> qgis-providers-common 1:2.18.4+24xenial-ubuntugis
>>> Regards,
>>> Jorge
>>> Às 18:05 de 22-03-2017, Jonathan Webb escreveu:
>>>> Hello,
>>>> Linux Mint 17.2
>>>> Eventually managed to reinstall QGIS, upgrading from 2.16 to 2.18.
>>>> Was working OKfor about a day (apart from missing geoprocessing/geometry
>>>> & analysis tools now mostly resolved), then started crashing out instantly.
>>>> I think I've tracked it down to applying a categorised style to a
>>>> polyline shapefile, some of the categories are turned off so they don't
>>>> display. I've been digitising against this on & off for a day & it was
>>>> OK, then suddenly started crashing.
>>>> In case it's relevant, my GRASS7 plugins aren't working either.
>>>> Cheers
>>>> Jonathan
>>>> Jonathan Webb
>>>> 07941 921905
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> J. Gustavo
> J. Gustavo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170323/96a1e3ad/attachment.html>
