[Qgis-user] QGIS 2.18 crashes on style by category
Matthias Kuhn matthias at opengis.ch
Thu Mar 23 10:23:52 PDT 2017
Hi Jonathan,
The most interesting part in GDB becomes visible as soon as you type
"bt" after a crash (I think the same if you kill it but no guarantee).
Thanks
Matthias
On 03/23/2017 06:11 PM, Jonathan Webb wrote:
> Hi Jorge,
> I uninstalled all my plugins & that project won't even open now.
> GDB report is:
> $ gdb -ex=r --args /usr/bin/qgis.bin
> GNU gdb (Ubuntu 7.7.1-0ubuntu5~14.04.2) 7.7.1
> Copyright (C) 2014 Free Software Foundation, Inc.
> License GPLv3+: GNU GPL version 3 or later
> <http://gnu.org/licenses/gpl.html>
> This is free software: you are free to change and redistribute it.
> There is NO WARRANTY, to the extent permitted by law.  Type "show copying"
> and "show warranty" for details.
> This GDB was configured as "x86_64-linux-gnu".
> Type "show configuration" for configuration details.
> For bug reporting instructions, please see:
> <http://www.gnu.org/software/gdb/bugs/>.
> Find the GDB manual and other documentation resources online at:
> <http://www.gnu.org/software/gdb/documentation/>.
> For help, type "help".
> Type "apropos word" to search for commands related to "word"...
> Reading symbols from /usr/bin/qgis.bin...(no debugging symbols
> found)...done.
> Starting program: /usr/bin/qgis.bin
> [Thread debugging using libthread_db enabled]
> Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
> Warning: loading of qgis translation failed
> [/usr/share/qgis/i18n//qgis_en_GB]
> Warning: loading of qt translation failed
> [/usr/share/qt4/translations/qt_en_GB]
> [New Thread 0x7fffcd875700 (LWP 11457)]
> [New Thread 0x7fffc7fff700 (LWP 11458)]
> [New Thread 0x7fffc75cf700 (LWP 11459)]
> [New Thread 0x7fffc6dce700 (LWP 11460)]
> Warning: QCss::Parser - Failed to load file  "/style.qss"
> QInotifyFileSystemWatcherEngine::addPaths: inotify_add_watch failed: No
> such file or directory
> [New Thread 0x7fffc65cd700 (LWP 11462)]
> Warning: QFileSystemWatcher: failed to add paths:
> /home/jonathan/.qgis2//project_templates
> [New Thread 0x7fffc5dcc700 (LWP 11463)]
> [New Thread 0x7fffc55cb700 (LWP 11464)]
> Warning: QLayout: Attempting to add QLayout "" to QgsPanelWidgetStack
> "mWidgetStack", which already has a layout
> [New Thread 0x7fff5e2e6700 (LWP 11492)]
> [New Thread 0x7fff5dae5700 (LWP 11527)]
> [New Thread 0x7fff5d2e4700 (LWP 11528)]
> [New Thread 0x7fff5cae3700 (LWP 11529)]
> Warning: QPainter::begin: A paint device can only be painted by one
> painter at a time.
> Warning: QPainter::setRenderHint: Painter must be active to set
> rendering hints
> Warning: QPainter::setBrush: Painter not active
> Warning: QPainter::setPen: Painter not active
> Warning: QPainter::translate: Painter not active
> Warning: QPainter::drawPath: Painter not active
> Warning: QPainter::end: Painter not active, aborted
> painter at a time.
> rendering hints
> [Thread 0x7fff5dae5700 (LWP 11527) exited]
> [Thread 0x7fff5e2e6700 (LWP 11492) exited]
> [Thread 0x7fff5d2e4700 (LWP 11528) exited]
> me killed it as unresponsive
> [Thread 0x7fff5cae3700 (LWP 11529) exited]
> [Thread 0x7fffc55cb700 (LWP 11464) exited]
> [Thread 0x7fffc65cd700 (LWP 11462) exited]
> [Thread 0x7fffc6dce700 (LWP 11460) exited]
> [Thread 0x7fffcd875700 (LWP 11457) exited]
> [Thread 0x7fffc75cf700 (LWP 11459) exited]
> [Thread 0x7fffc7fff700 (LWP 11458) exited]
> [Thread 0x7fffc5dcc700 (LWP 11463) exited]
> Program terminated with signal SIGKILL, Killed.
> The program no longer exists.
> This doesn't tell me much
> I've been advised to file a bug report, so am waiting for an OSGEO account.
> Cheers
> jonathan
> Jonathan Webb
> Freelance GIS Specialist
> 07941 921905
> http://www.jwebbgis.co.uk
> http://uk.linkedin.com/in/jwebbgis
> On 22/03/17 19:15, Jorge Gustavo Rocha wrote:
>> Hi Jonathan,
>> Às 18:56 de 22-03-2017, Jonathan Webb escreveu:
>>> Hi Jorge,
>>> Thanks,
>>> 1.    Not sure you mean "without anything else installed"?  I moved the
>>> backup ~qgs file & still crashes.
>> I meant without any plugin installed. Plugins might cause problems when
>> changing QGIS version.
>> Try to start with gdb just to see the reason for crashing. On the terminal:
>> Regards,
>> Jorge
>>> 2    I used ppa:ubuntugis/ubuntugis-unstable
>>> 2.1
>>> $ dpkg -l | grep qgis | awk '{print $2, $3}'
>>> libqgis-analysis2.18.4 1:2.18.4+20trusty-ubuntugis
>>> libqgis-app2.18.4 1:2.18.4+20trusty-ubuntugis
>>> libqgis-core2.18.4 1:2.18.4+20trusty-ubuntugis
>>> libqgis-customwidgets 1:2.18.4+20trusty-ubuntugis
>>> libqgis-gui2.18.4 1:2.18.4+20trusty-ubuntugis
>>> libqgis-networkanalysis2.18.4 1:2.18.4+20trusty-ubuntugis
>>> libqgis-server2.18.4 1:2.18.4+20trusty-ubuntugis
>>> libqgisgrass7-2.18.4 1:2.18.4+20trusty-ubuntugis
>>> libqgispython2.18.4 1:2.18.4+20trusty-ubuntugis
>>> python-qgis 1:2.18.4+20trusty-ubuntugis
>>> python-qgis-common 1:2.18.4+20trusty-ubuntugis
>>> qgis-plugin-grass 1:2.18.4+20trusty-ubuntugis
>>> qgis-plugin-grass-common 1:2.18.4+20trusty-ubuntugis
>>> qgis-provider-grass 1:2.18.4+20trusty-ubuntugis
>>> qgis-providers 1:2.18.4+20trusty-ubuntugis
>>> qgis-providers-common 1:2.18.4+20trusty-ubuntugis
>>> Cheers
>>> Jonathan
>>> Jonathan Webb
>>> 07941 921905
>>> On 22/03/17 18:35, Jorge Gustavo Rocha wrote:
>>>> Hi Jonathan,
>>>> 1. Try to remove (backup first) your ~/.qgis2 folder, to start qgis
>>>> without anything else installed.
>>>> 2. Which repository did you use to install QGIS?
>>>> 2.1 Can you provide a list of all qgis related packages, to check if
>>>> there are any package conflicts or packages coming from different
>>>> repositories/version?
>>>> Can you try something like:
>>>> On my system, I've installed QGIS from ubuntugis respository. The result
>>>> of the above command is:
>>>> libqgis-analysis2.18.4 1:2.18.4+24xenial-ubuntugis
>>>> libqgis-app2.18.4 1:2.18.4+24xenial-ubuntugis
>>>> libqgis-core2.18.4 1:2.18.4+24xenial-ubuntugis
>>>> libqgis-customwidgets 1:2.18.4+24xenial-ubuntugis
>>>> libqgis-gui2.18.4 1:2.18.4+24xenial-ubuntugis
>>>> libqgis-networkanalysis2.18.4 1:2.18.4+24xenial-ubuntugis
>>>> libqgis-server2.18.4 1:2.18.4+24xenial-ubuntugis
>>>> libqgisgrass7-2.18.4 1:2.18.4+24xenial-ubuntugis
>>>> libqgispython2.18.4 1:2.18.4+24xenial-ubuntugis
>>>> python-qgis 1:2.18.4+24xenial-ubuntugis
>>>> python-qgis-common 1:2.18.4+24xenial-ubuntugis
>>>> qgis-plugin-globe 1:2.18.4+24xenial-ubuntugis
>>>> qgis-plugin-globe-common 1:2.18.4+24xenial-ubuntugis
>>>> qgis-plugin-grass 1:2.18.4+24xenial-ubuntugis
>>>> qgis-plugin-grass-common 1:2.18.4+24xenial-ubuntugis
>>>> qgis-provider-grass 1:2.18.4+24xenial-ubuntugis
>>>> qgis-providers 1:2.18.4+24xenial-ubuntugis
>>>> qgis-providers-common 1:2.18.4+24xenial-ubuntugis
>>>> Regards,
>>>> Jorge
>>>> Às 18:05 de 22-03-2017, Jonathan Webb escreveu:
>>>>> Hello,
>>>>> Linux Mint 17.2
>>>>> Eventually managed to reinstall QGIS, upgrading from 2.16 to 2.18.
>>>>> Was working OKfor about a day (apart from missing geoprocessing/geometry
>>>>> & analysis tools now mostly resolved), then started crashing out instantly.
>>>>> I think I've tracked it down to applying a categorised style to a
>>>>> polyline shapefile, some of the categories are turned off so they don't
>>>>> display. I've been digitising against this on & off for a day & it was
>>>>> OK, then suddenly started crashing.
>>>>> In case it's relevant, my GRASS7 plugins aren't working either.
>>>>> Cheers
>>>>> Jonathan
>>>>> Jonathan Webb
>>>>> 07941 921905
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> J. Gustavo
>> J. Gustavo
