[Qgis-user] API REQUIRED from OSM cycle map
Frederico dos Santos Soares
fssunb at gmail.com
Fri Mar 24 04:10:44 PDT 2017
Hi everybody I'm having some problems with the OpenStreetMap's services in
openlyers's plugin.
In fact the problem is the 'API Require Key' in cyclemap.
I did my login in Thunderforest and with the URL (with my token) given by
Thunderforest's site, I substituted the URL in OpenLyers's files (xml and
html files).
This is an exemple of URL that I used:
https://{s}.tile.thunderforest.com/cycle/{z}/{x}/{y}.png?apikey=cc63d6d...
I alredy tried remove the {s} from URL
I'm using QGIS2.14.
Someone had passed thru the same thing and solve the problem?
Thanks.
Geógrafo
55 61 8416 0105
fssunb at gmail.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170324/9c012f3c/attachment.html>
