[Qgis-user] API REQUIRED from OSM cycle map
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Fri Mar 24 08:49:18 PDT 2017
is there a specific need for you to use the OpenLayers plugin?
Maybe you could try to add the service to the QuickMapServices plugin more
easily (under settings)
Cheers
Bernd
Am 24.03.2017, 12:10 Uhr, schrieb Frederico dos Santos Soares
<fssunb at gmail.com>:
> Hi everybody I'm having some problems with the OpenStreetMap's services
> in openlyers's plugin.In fact the problem is the 'API Require Key' in
> cyclemap.I did my login in Thunderforest and with the URL (with my
> token)  given by Thunderforest's site, I substituted the URL in
> >OpenLyers's files (xml and html files).
> This is an exemple of URL that I used:
> https://{s}.tile.thunderforest.com/cycle/{z}/{x}/{y}.png?apikey=cc63d6d...
> I alredy tried remove the {s} from URL
> I'm using QGIS2.14.
> Someone had passed thru the same thing and solve the problem?
> Thanks.
> Geógrafo
> 55 61 8416 0105
> fssunb at gmail.com
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170324/9ca6b8dc/attachment.html>
