[Qgis-user] PostGIS Query - DB Manager Not Recognizing Geom Column
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Mar 27 22:40:16 PDT 2017
you need to explicitly state the geometry type and SRS in you view
definition like this:
CREATE OR REPLACE VIEW test.testbuff as
SELECT gid, area_id,
st_buffer(testshape.geom, 100)::geometry(Polygon,your_srs_code)
as geom2 FROM test.testshape where testshape.area_id=100;
could be Polygon or Multipolygon depending on the input, your_srs_code
should be the same as testshape's
QGIS can analyze geometry columns and detect the type (and probably
SRS), however only relations with geometry fields defined in this way
are listed in geometry_columns.
Bernhard
Am 27.03.2017 um 23:42 schrieb Michael Treglia:
> Hi All,
> I'm running a PostGIS query to create a view, buffering a polygon -
> viewing the result in DB Manager, the associated icon, rather than being
> polygons, is a question mark, and in the info tab for the layer, I see
> the warning ' There is no entry in geometry_columns!'
> That said, the layer actually displays fine in QGIS, and in the list of
> fields, the appropriate column is labeled as Type 'geometry'.
> Thus, is this really a problem? And if so, any easy fixes? A sample
> query is below:
> SELECT gid, area_id, st_buffer(testshape.geom, 100)
> Thanks for any suggestions!
> Mike
> Qgis-user mailing list
__________ Information from ESET Mail Security, version of virus signature database 15160 (20170328) __________
The message was checked by ESET Mail Security.
http://www.eset.com
