[Qgis-user] PostGIS Query - DB Manager Not Recognizing Geom Column
Michael Treglia
mtreglia at gmail.com
Tue Mar 28 05:59:32 PDT 2017
Ah, this makes perfect sense - I figured that I needed to define the
geometry type, just wasn't quite figuring out how. Nice and simple solution!
Thanks so much,
Mike
On Tue, Mar 28, 2017 at 1:40 AM, Bernhard Ströbl <bernhard.stroebl at jena.de>
wrote:
> Hi,
> you need to explicitly state the geometry type and SRS in you view
> definition like this:
> CREATE OR REPLACE VIEW test.testbuff as
> SELECT gid, area_id,
> st_buffer(testshape.geom, 100)::geometry(Polygon,your_srs_code)
> as geom2 FROM test.testshape where testshape.area_id=100;
> could be Polygon or Multipolygon depending on the input, your_srs_code
> should be the same as testshape's
> QGIS can analyze geometry columns and detect the type (and probably SRS),
> however only relations with geometry fields defined in this way are listed
> in geometry_columns.
> Bernhard
> Am 27.03.2017 um 23:42 schrieb Michael Treglia:
>> Hi All,
>> I'm running a PostGIS query to create a view, buffering a polygon -
>> viewing the result in DB Manager, the associated icon, rather than being
>> polygons, is a question mark, and in the info tab for the layer, I see
>> the warning ' There is no entry in geometry_columns!'
>> That said, the layer actually displays fine in QGIS, and in the list of
>> fields, the appropriate column is labeled as Type 'geometry'.
>> Thus, is this really a problem? And if so, any easy fixes? A sample
>> query is below:
>> SELECT gid, area_id, st_buffer(testshape.geom, 100)
>> Thanks for any suggestions!
>> Mike
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> __________ Information from ESET Mail Security, version of virus signature
> database 15160 (20170328) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170328/16dcb1f2/attachment.html>
