[Qgis-user] qgis installation problems
Filipe Dias
filipesdias at gmail.com
Wed Mar 29 02:26:14 PDT 2017
Hi
I am on Ubuntu 16.04 and trying a fresh installtion of the latest 2.18.x
version with ubuntugis dependencies. I have both "ubuntugis unstable" and
http://qgis.org/ubuntugis". However this happens:
fd at fd-XPS:~$ sudo apt-get install qgis python-qgis
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
python-qgis : Depends: libqgis-analysis2.18.5 but it is not going to be
installed
Depends: libqgis-server2.18.5 but it is not going to be
installed
qgis : Depends: gdal-abi-2-1-2 but it is not installable
Depends: libqgis-analysis2.18.5 but it is not going to be installed
Depends: libqgis-app2.18.5 but it is not going to be installed
Recommends: qgis-plugin-globe but it is not going to be installed
Recommends: qgis-plugin-grass but it is not going to be installed
Recommends: qgis-provider-grass but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Am I doing something wrong?
Thanks
Cheers
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170329/3c90b2a7/attachment.html>
