[Qgis-user] qgis installation problems
Randal Hale
rjhale at northrivergeographic.com
Wed Mar 29 04:33:42 PDT 2017
If I understand correctly there is a new version of GDAL in UbuntuGIS
that is causing a conflict. They are working to resolve it. For instance
- I am on 2.18.4 and can't upgrade currently. I would install just from
the QGIS Repository and wait a bit - then upgrade to UbuntuGIS in a few
days.
Randy
On 03/29/2017 05:26 AM, Filipe Dias wrote:
> Hi
> I am on Ubuntu 16.04 and trying a fresh installtion of the latest
> 2.18.x version with ubuntugis dependencies. I have both "ubuntugis
> unstable" and http://qgis.org/ubuntugis". However this happens:
> fd at fd-XPS:~$ sudo apt-get install qgis python-qgis
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
> python-qgis : Depends: libqgis-analysis2.18.5 but it is not going to
> be installed
> Depends: libqgis-server2.18.5 but it is not going to be
> installed
> qgis : Depends: gdal-abi-2-1-2 but it is not installable
> Depends: libqgis-analysis2.18.5 but it is not going to be
> installed
> Depends: libqgis-app2.18.5 but it is not going to be installed
> Recommends: qgis-plugin-globe but it is not going to be installed
> Recommends: qgis-plugin-grass but it is not going to be installed
> Recommends: qgis-provider-grass but it is not going to be
> installed
> E: Unable to correct problems, you have held broken packages.
> Am I doing something wrong?
> Thanks
> Cheers
> Qgis-user mailing list
Randal Hale
North River Geographic Systems, Inc
http://www.northrivergeographic.com
423.653.3611 rjhale at northrivergeographic.com
twitter:rjhale
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170329/a4dc427b/attachment.html>
