[Qgis-user] QGIS 2.18.2 Crashes often on Mac (Yosemite 10.10.5)
    NPE NewPathEconometrics
    newpatheconometrics at gmail.com
    Thu Mar 30 12:52:59 PDT 2017
Thank you.
I can't reliably "reproduce it" other than knowing that when I have certain
multiple layers loaded through a connection in my PostgreSQL database, it
can happen often when I pan or zoom the map. As somebody else pointed out,
after looking at the stack trace information I posted, it seems to be a
specific to drawing a marker symbol...
> "Your stack indicates the Qt crashed trying to draw an ellipse, as
> invoked by QGIS while attempting to start rendering of a marker symbol.
> This is probably a straightforward crash to resolve by someone familiar
> with the code."
I can try to get a more specific set of repro steps, but I think it will be
hard to get others to repro it, unless I give my PostgreSQL database to
others? I might see if I can repro it with just SHP files, instead of using
a connection to the DB. If that is possible, then perhaps I can make these
SHP files available to others by posting them somewhere.
I was hoping that the stack trace information might be useful to "the
devs"?
Also, if this is just an issue with Macs, or how the libraries are built,
is there a way for me to narrow that down? BTW, I only have this Mac to run
QGIS, so I can't test it on another machine.
Thanks again. I'll see if I can identify a set of "sure fire" repro steps
for this.
Regards
On Wed, Mar 29, 2017 at 11:39 PM, Richard Duivenvoorde <rdmailings at duif.net>
wrote:
> On 30-03-17 03:39, NPE NewPathEconometrics wrote:
> > The relevant response from John H was:
> > with the code."
> > I'm new to using these lists and fairly new to QGIS. Should I file this
> > as a bug with the QGIS group?
> Sure, a crash is always a bad thing.
> And if you provide enough information, others can try to reproduce it
> first (with exact the data (or parts of it) or the steps you did to make
> it crash).
> Please provide as much information as possible, as non devs can then try
> to reproduce your crash. Maybe also try if you can reproduce the crash
> on another machine too? To be sure it is not a local
> installation/library problem.
> For more info, see:
> http://qgis.org/en/site/getinvolved/development/bugreporting.html#bugs-
> features-and-issues
> I'll sent you the mantra you need to registre in a private email.
> Regards,
> Richard
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170330/e7e7542f/attachment.html>
