[Qgis-user] QGIS web client & Joins
Julian Bogdani jbogdani at gmail.com
Thu May 4 23:53:43 PDT 2017
Hello,
I’m having an issue with joins in a webGIS project using Qgis as a map server and Qgis web client.
I have an external table (sqlite) correctly joined to a shape file on my desktop project, but the joined attributes do not show on the web project. I thought the sqlite could be the problem so I tried with CSV and DBF, so I guess it’s not a file type problem.
Are joins supported? I did not find any docs on this. I see somebody else had this problem before, but the qgis issue had been moved (https://hub.qgis.org/issues/5324)..
Thank you
Julian Bogdani
http://bradypus.net
