[Qgis-user] QGIS web client & Joins
Neumann, Andreas a.neumann at carto.net
Fri May 5 01:26:14 PDT 2017
Hi Julian,
The issue you mention doesn't exist.
I doubt that this is a QGIS web client issue. Did you test with QGIS as
WMS client? Does it work there?
If it doesn't work there either, than this is can most likely be a
"path-issue" (absolute vs. relativ paths) or a QGIS server issue.
Andreas
On 2017-05-05 08:53, Julian Bogdani wrote:
> Hello,
> I'm having an issue with joins in a webGIS project using Qgis as a map server and Qgis web client.
> I have an external table (sqlite) correctly joined to a shape file on my desktop project, but the joined attributes do not show on the web project. I thought the sqlite could be the problem so I tried with CSV and DBF, so I guess it's not a file type problem.
> Are joins supported? I did not find any docs on this. I see somebody else had this problem before, but the qgis issue had been moved (https://hub.qgis.org/issues/5324)..
> Thank you
> Julian Bogdani
> jbogdani at gmail.com
> http://bradypus.net
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170505/07349e14/attachment.html>
