[Qgis-user] QGIS web client & Joins
    BraDypUS. Communicating Cultural Heritage
    info at bradypus.net
    Fri May  5 01:30:57 PDT 2017
Yes, I had a preview of the issue in Google, but the ussue itself has been
(re)moved.
I'll check bettee the wms service.
Thank you
Il 05 Mag 2017 10:26 AM, "Neumann, Andreas" <a.neumann at carto.net> ha
scritto:
> Hi Julian,
> The issue you mention doesn't exist.
> I doubt that this is a QGIS web client issue. Did you test with QGIS as
> WMS client? Does it work there?
> If it doesn't work there either, than this is can most likely be a
> "path-issue" (absolute vs. relativ paths) or a QGIS server issue.
> Andreas
> On 2017-05-05 08:53, Julian Bogdani wrote:
> Hello,
> I'm having an issue with joins in a webGIS project using Qgis as a map
> server and Qgis web client.
> I have an external table (sqlite) correctly joined to a shape file on my
> desktop project, but the joined attributes do not show on the web project.
> I thought the sqlite could be the problem so I tried with CSV and DBF, so I
> guess it's not a file type problem.
> Are joins supported? I did not find any docs on this. I see somebody else
> had this problem before, but the qgis issue had been moved (
> https://hub.qgis.org/issues/5324)..
> Thank you
> Julian Bogdani
> jbogdani at gmail.com
> http://bradypus.net
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170505/d0ad1f2d/attachment.html>
