[Qgis-user] QGIS web client & Joins
BraDypUS. Communicating Cultural Heritage
info at bradypus.net
Fri May 5 01:32:59 PDT 2017
In fact I had a preview of the snippet of the issue on Google, but the
issue itself is not available anymore.
I'll try to check better the wms service.
Thank you
Il 05 Mag 2017 10:30 AM, "BraDypUS. Communicating Cultural Heritage" <
info at bradypus.net> ha scritto:
> Yes, I had a preview of the issue in Google, but the ussue itself has been
> (re)moved.
> I'll check bettee the wms service.
> Thank you
> Il 05 Mag 2017 10:26 AM, "Neumann, Andreas" <a.neumann at carto.net> ha
> scritto:
>> Hi Julian,
>> The issue you mention doesn't exist.
>> I doubt that this is a QGIS web client issue. Did you test with QGIS as
>> WMS client? Does it work there?
>> If it doesn't work there either, than this is can most likely be a
>> "path-issue" (absolute vs. relativ paths) or a QGIS server issue.
>> Andreas
>> On 2017-05-05 08:53, Julian Bogdani wrote:
>> Hello,
>> I'm having an issue with joins in a webGIS project using Qgis as a map
>> server and Qgis web client.
>> I have an external table (sqlite) correctly joined to a shape file on my
>> desktop project, but the joined attributes do not show on the web project.
>> I thought the sqlite could be the problem so I tried with CSV and DBF, so I
>> guess it's not a file type problem.
>> Are joins supported? I did not find any docs on this. I see somebody else
>> had this problem before, but the qgis issue had been moved (
>> https://hub.qgis.org/issues/5324)..
>> Thank you
>> Julian Bogdani
>> jbogdani at gmail.com
>> http://bradypus.net
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170505/305ad385/attachment.html>
