[Qgis-user] Keeping only POIs X kms from a trace?
Winfried
codecomplete at free.fr
Tue May 9 02:22:34 PDT 2017
Thank you.
Turns out I was pretty close to the solution: The error was in the order
parameters were set in the Spatial Query dialog. Also, there is no
information on the unit used for Distance in the Fixed Distance Buffer; I
guess "0,05" means 5kms.
<http://osgeo-org.1560.x6.nabble.com/file/n5319849/QGIS.png>
I'll see if a simple Python script can perform the same thing, or even split
campsites into regions instead of whole nations.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Keeping-only-POIs-X-kms-from-a-trace-tp5319730p5319849.html
Sent from the QGIS - User mailing list archive at Nabble.com.
