[Qgis-user] Interpolation, include breaklines for buildings
Nicolas Cadieux
nicolas.cadieux at archeotec.ca
Fri May 12 08:16:48 PDT 2017
I am not sure I understand but why not just use the ground points and the building points together in the same DEM? Do you only have the ground classified points?
Nicolas
> Le 12 mai 2017 à 10:05, KevinKnoche [via OSGeo.org] <ml+s1560n5320349h80 at n6.nabble.com> a écrit :
> Hey there,
> I'm currently working on a project concerning heavy rainfalls. What I'm supposed to do is an 2D numerical calculation of flooded area of a town. For this I have a special plugin for QGIS.
> What this plugin needs is a precise DEM includes breaklines of buildings, walls etc.
> I've already managed to build up a DEM from LIDAR Data including some breaklines with Z-Values.
> What makes some trouble is the fact, that I only managed to include the breaklines for the buildings like a bowl so that they only have foundation walls and no roof. So if it would rain they will be filled up with water instead of contributing to the surface runoff.
> Does somebody of you have an idea how to include roofs onto the breaklines? Plane ones would be precise enough.
> Thanks a lot :)
> Kevin
> If you reply to this email, your message will be added to the discussion below:
> http://osgeo-org.1560.x6.nabble.com/Interpolation-include-breaklines-for-buildings-tp5320349.html
> To start a new topic under QGIS - User, email ml+s1560n4125267h38 at n6.nabble.com
> To unsubscribe from QGIS - User, click here.
> NAML
View this message in context: http://osgeo-org.1560.x6.nabble.com/Interpolation-include-breaklines-for-buildings-tp5320349p5320362.html
Sent from the QGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170512/4b0960e9/attachment.html>
