[Qgis-user] [processing] connect selection input in model
Andreas Plesch
andreasplesch at netscape.net
Wed May 17 07:41:51 PDT 2017
I have a selection input parameter in a processing script and would like to
use it in a model.
However, as far as I can see there is no way to connect the selection input
parameter to an output parameter of another script.
This is probably because there is no matching 'selected selection' output
type. Such a 'selected selection' output type could be either a string
matching one of selection options, or an integer index into the array of
selections.
Is there a recommended workaround ?
I may use a series of (pseudo) boolean input parameters instead as in:
x use Option A
x use Option B
Any thoughts or ideas very welcome,
-Andreas
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170517/1cfa6fce/attachment.html>
