[Qgis-user] Magnetic declination
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Wed May 17 08:47:51 PDT 2017
Can Vector Affine Transformation plugin do the job?
Thanks,
Marian
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Nicolas Cadieux
Sent: May-17-17 9:53 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Magnetic declination
https://www.youtube.com/watch?v=7TN3toqcyks
Le 17 mai 2017 à 09:02, Tudorache, Marian [via OSGeo.org<http://OSGeo.org>] <[hidden email]</user/SendEmail.jtp?type=node&node=5320828&i=0>> a écrit :
Hi everyone,
I have a map build in True Geographic North.
I have used the Magnetic Declination plugin build by Aldo Scorza, to calculated magnetic declination on various points on the map.
I would like to know if there is a way to rotate the map on the fly with declination angle.
Thanks,
Marian
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
Qgis-user mailing list
[hidden email]</user/SendEmail.jtp?type=node&node=5320815&i=0>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.x6.nabble.com/Magnetic-declination-tp5320815.html
To start a new topic under QGIS - User, email [hidden email]</user/SendEmail.jtp?type=node&node=5320828&i=1>
To unsubscribe from QGIS - User, click here.
NAML<http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: Re: Magnetic declination<http://osgeo-org.1560.x6.nabble.com/Magnetic-declination-tp5320815p5320828.html>
Sent from the QGIS - User mailing list archive<http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html> at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170517/ea7984bf/attachment.html>
