[Qgis-user] Layer Styling Panel Crash
Alexandre Neto
senhor.neto at gmail.com
Wed May 17 23:11:08 PDT 2017
Do you have any plugins installed? Can you try with all Plugins deactivated?
Just to make sure it's not a plugin that is causing the problem.
Thanks
A qui, 18/05/2017, 01:03, <agrifolia at tutanota.com> escreveu:
> I just downloaded 2.18.7 and am using mac os sierra. I've been going
> through the qgis tutorials and am currently on 4.2: The Label Tool. The
> label panel appears in its default spot on the right of the window when I
> open it. When I tried to free the panel by dragging the panel from the top
> and also clicking the freeing icon the program quits unexpectedly.
> Qgis-user mailing list
Alexandre Neto
@AlexNetoGeo
http://sigsemgrilhetas.wordpress.com
http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170518/d69dd4b7/attachment.html>
