[Qgis-user] Layer Styling Panel Crash
    agrifolia at tutanota.com
    Thu May 18 08:51:53 PDT 2017
I've only done the stock download.
17. May 2017 23:11 by senhor.neto at gmail.com:
> Hi,
> Do you have any plugins installed? Can you try with all Plugins deactivated?
> Just to make sure it's not a plugin that is causing the problem.
> Thanks
> A qui, 18/05/2017, 01:03,  <> agrifolia at tutanota.com> > escreveu:
>>           >> I just downloaded 2.18.7 and am using mac os sierra. I've been going through the qgis tutorials and am currently on 4.2: The Label Tool. The label panel appears in its default spot on the right of the window when I open it. When I tried to free the panel by dragging the panel from the top and also clicking the freeing icon the program quits unexpectedly.
>>   >> _______________________________________________
>> Qgis-user mailing list
>> List info: >> https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: >> https://lists.osgeo.org/mailman/listinfo/qgis-user
> Alexandre Neto> ---------------------> @AlexNetoGeo> http://sigsemgrilhetas.wordpress.com> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170518/ccfc9106/attachment.html>
