[Qgis-user] Moving selected feature to the top of attribute table does not seem to work in 2.18.7
Matthias Kuhn 🌍
matthias at opengis.ch
Thu May 18 02:03:50 PDT 2017
... or install qgis-rel-dev from osgeo4w network installer if you are on
windows and don't feel like compiling.
https://www.qgis.org/en/site/forusers/download.html
Matthias
On 05/18/2017 11:00 AM, Luigi Pirelli wrote:
> Can you try to compile from this source code branch?
> https://github.com/qgis/QGIS/tree/release-2_18
> just to be sure that the issue has completly fixed.
> regards
> Luigi Pirelli
> * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Mastering QGIS 2nd Edition:
> * https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
> On 18 May 2017 at 10:31, Hernán De Angelis <dhdeangelis at gmail.com> wrote:
>> Thank you for your fast response, Luigi.
>> I understand. I can wait for the next release, no problem. As for the
>> <someValue> question, I will have a look and come back with whatever I find,
>> but when I found this I wasn't working on any particular project nor using
>> composer either.
>> Cheers
>> Hernán
>> On Thu, May 18, 2017 at 10:12 AM, Luigi Pirelli <luipir at gmail.com> wrote:
>>> fixed during the hackfest on current 2.18 code (you have to wait for
>>> 2.18.8... or update to the latest 2.18 code not the tagged release
>>> version)
>>> https://github.com/qgis/QGIS/pull/4306
>>> and 3.0
>>> https://github.com/qgis/QGIS/pull/4444
>>> btw there are some simple workaround to fix temporarly waiting the patch
>>> release
>>> workaround 1) in the attribute table, apply a sort on some column =>
>>> apply sortOnTop
>>> workaround 2) in your project xml file you should have a tag as:
>>> <attributetableconfig ... sortOrder="<someValue>" >
>>> in your case <someValue> is something different from 0 (Ascending) or
>>> 1 (Descending)... fix it and sortOnTop will be back :)
>>> btw, pelase let me knwo what value is in <someValue>, because is not
>>> clear who's set it to a strange value (probably the composer)
>>> cheers
>>> Luigi Pirelli
>>> On 18 May 2017 at 10:03, Hernán De Angelis <dhdeangelis at gmail.com> wrote:
>>>> Hi
>>>> Yesterday I compiled from source QGIS 2.18.7 in openSUSE Leap 42.2
>>>> Linux.
>>>> Everything went fine and there were no problems with the compilation.
>>>> However, when using the new installation I realized that the function
>>>> that
>>>> allows to move the attribute row of a selected feature to the top of the
>>>> attribute table does not seem to work. This problem was not present in
>>>> my
>>>> previously installed version (2.18.6), nor in another machine I use
>>>> (QGIS
>>>> 2.14.2, Windows 7) using the same data. I wonder if any other users are
>>>> experiencing this in 2.18.7, or there is just something wrong with my
>>>> particular installation.
>>>> Regards,
>>>> Hernán
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
