[Qgis-user] Moving selected feature to the top of attribute table does not seem to work in 2.18.7
Hernán De Angelis dhdeangelis at gmail.com
Thu May 18 02:22:37 PDT 2017
Thank you for this. Unfortunately I have no admin privileges to install
things in my Windows environment, so I will not be able to test.
H.
Den 18 maj 2017 11:03 fm skrev "Matthias Kuhn 🌍" <matthias at opengis.ch>:
> ... or install qgis-rel-dev from osgeo4w network installer if you are on
> windows and don't feel like compiling.
> https://www.qgis.org/en/site/forusers/download.html
> Matthias
> On 05/18/2017 11:00 AM, Luigi Pirelli wrote:
> > Can you try to compile from this source code branch?
> > https://github.com/qgis/QGIS/tree/release-2_18
> > just to be sure that the issue has completly fixed.
> > regards
> > Luigi Pirelli
> > * Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
> > * LinkedIn: https://www.linkedin.com/in/luigipirelli
> > * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> > * GitHub: https://github.com/luipir
> > * Mastering QGIS 2nd Edition:
> > * https://www.packtpub.com/big-data-and-business-
> intelligence/mastering-qgis-second-edition
> > On 18 May 2017 at 10:31, Hernán De Angelis <dhdeangelis at gmail.com>
> wrote:
> >> Thank you for your fast response, Luigi.
> >> I understand. I can wait for the next release, no problem. As for the
> >> <someValue> question, I will have a look and come back with whatever I
> find,
> >> but when I found this I wasn't working on any particular project nor
> using
> >> composer either.
> >> Cheers
> >> Hernán
> >> On Thu, May 18, 2017 at 10:12 AM, Luigi Pirelli <luipir at gmail.com>
> wrote:
> >>> fixed during the hackfest on current 2.18 code (you have to wait for
> >>> 2.18.8... or update to the latest 2.18 code not the tagged release
> >>> version)
> >>> https://github.com/qgis/QGIS/pull/4306
> >>> and 3.0
> >>> https://github.com/qgis/QGIS/pull/4444
> >>> btw there are some simple workaround to fix temporarly waiting the
> patch
> >>> release
> >>> workaround 1) in the attribute table, apply a sort on some column =>
> >>> apply sortOnTop
> >>> workaround 2) in your project xml file you should have a tag as:
> >>> <attributetableconfig ... sortOrder="<someValue>" >
> >>> in your case <someValue> is something different from 0 (Ascending) or
> >>> 1 (Descending)... fix it and sortOnTop will be back :)
> >>> btw, pelase let me knwo what value is in <someValue>, because is not
> >>> clear who's set it to a strange value (probably the composer)
> >>> cheers
> >>> Luigi Pirelli
> >>> On 18 May 2017 at 10:03, Hernán De Angelis <dhdeangelis at gmail.com>
> wrote:
> >>>> Hi
> >>>> Yesterday I compiled from source QGIS 2.18.7 in openSUSE Leap 42.2
> >>>> Linux.
> >>>> Everything went fine and there were no problems with the compilation.
> >>>> However, when using the new installation I realized that the function
> >>>> that
> >>>> allows to move the attribute row of a selected feature to the top of
> the
> >>>> attribute table does not seem to work. This problem was not present in
> >>>> my
> >>>> previously installed version (2.18.6), nor in another machine I use
> >>>> (QGIS
> >>>> 2.14.2, Windows 7) using the same data. I wonder if any other users
> are
> >>>> experiencing this in 2.18.7, or there is just something wrong with my
> >>>> particular installation.
> >>>> Regards,
> >>>> Hernán
> >>>> _______________________________________________
> >>>> Qgis-user mailing list
> >>>> Qgis-user at lists.osgeo.org
> >>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> >>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170518/eda5cf24/attachment.html>
