[Qgis-user] Error compiling QGIS 2.18.8: "QStringLiteral was not declared in this scope"
Hernán De Angelis dhdeangelis at gmail.com
Thu May 25 01:49:18 PDT 2017
Thanks Jürgen and Larry for your fast responses!
Now I sit here trying to get this to work in my machine. Downloaded the
latest master from GitHub and see that now it can only accept qt5 and py3.
QGIS is moving fast!
Cheers and thanks again!
/Hernán
On Thu, May 25, 2017 at 8:34 AM, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Larry,
> On Wed, 24. May 2017 at 15:33:00 -0600, Larry Shaffer wrote:
> > Side note: I have gotten around it for C++ plugin development, where I
> > wanted to compile the same plugin code for QGIS 2 and 3 while focusing
> more
> > on QGIS 3 coding style/standards, by using the following macro:
> That is also in recent versions of qca.  So this bug only unfolded on
> platforms
> that had older versions (jessie/trusty) - which initially was a bit
> puzzling.
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel.
> +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
> +49-4931-918175-50
> Software Engineer           D-26506 Norden
> http://www.norbit.de
> QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20170525/553bdbc5/attachment.html>
