[Qgis-user] Building models in QGIS
Tyler Veinot
tylerkveinot at gmail.com
Thu Nov 2 05:56:29 PDT 2017
Andreas;
Thanks for the reply; I knew there was a QGIS 3 in the works but I didn't
think there was a 'working/usable' dev out, thanks for that. I am certainly
going to install and play around with it.
Tyler
On Thu, Nov 2, 2017 at 9:17 AM, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi Tyler,
> 3D visualization will be a core feature in QGIS 3.
> If you want to play with 3D visualization, I recommend that you try/test
> QGIS 3, even if it is still in bug fixing mode and not officially released.
> You can either use the OSGeo4W installer and install the dev version or
> use the weeklies (the newest one published at http://qgis.org/downloads/
> weekly/?C=M;O=D).
> See also http://www.lutraconsulting.co.uk/blog/2017/10/16/buildings-in-
> qgis3d/ and https://twitter.com/lutraconsulting
> Martin Dobias from Lutra is the main developer of the new 3D viz
> functionality in QGIS 3.
> Greetings,
> Andreas
> On 2017-11-02 13:02, Tyler Veinot wrote:
> Hello;
> Is anyone out there doing anything with building models in QGIS? I have
> some sketchup buildings in DXF format I have been playing with in AutoCAD
> and QGIS. Trying to find a way to bring them into QGIS for viewing in the
> qgs2threejs plugin, but when I do I get a crash dump.
> Tried a simple cube as well.
> I can bring in Z aware dxf files and view them so I am wondering how big
> of a step is it to go from there to simple building models? Is anyone
> working in this direction that has some insights or thoughts to share?
> Thanks;
> Tyler
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171102/272601e8/attachment.html>
