[Qgis-user] Building models in QGIS
Andreas Neumann
a.neumann at carto.net
Thu Nov 2 05:17:07 PDT 2017
Hi Tyler,
3D visualization will be a core feature in QGIS 3.
If you want to play with 3D visualization, I recommend that you try/test
QGIS 3, even if it is still in bug fixing mode and not officially
released.
You can either use the OSGeo4W installer and install the dev version or
use the weeklies (the newest one published at
http://qgis.org/downloads/weekly/?C=M;O=D).
See also
http://www.lutraconsulting.co.uk/blog/2017/10/16/buildings-in-qgis3d/
and https://twitter.com/lutraconsulting
Martin Dobias from Lutra is the main developer of the new 3D viz
functionality in QGIS 3.
Greetings,
Andreas
On 2017-11-02 13:02, Tyler Veinot wrote:
> Hello;
> Is anyone out there doing anything with building models in QGIS? I have some sketchup buildings in DXF format I have been playing with in AutoCAD and QGIS. Trying to find a way to bring them into QGIS for viewing in the qgs2threejs plugin, but when I do I get a crash dump.
> Tried a simple cube as well.
> I can bring in Z aware dxf files and view them so I am wondering how big of a step is it to go from there to simple building models? Is anyone working in this direction that has some insights or thoughts to share?
> Thanks;
> Tyler
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171102/06a9b583/attachment.html>
