[Qgis-user] Building models in QGIS
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Thu Nov 2 11:37:41 PDT 2017
HI Tyler,
Did you try to enable 3d styling for your vectors (available from Style
panel)?
No other dependcy is needed. The documentation for 3 is underway but you
can refer to the links from Andreas' email.
Regards
Saber
On 2 Nov 2017 4:53 pm, "Tyler Veinot" <tylerkveinot at gmail.com> wrote:
Andreas;
I installed the QGIS 2.99 and added some data, the 3D map seems to work
well with grid/raster dems but it doesn't display XYZ/XYZM geometries based
on the Z coordinate. I only did a basic install using the downloadable
installer; is there other dependencies I should install or is it only for
viewing rasters and DEM's in 3D?
Tyler
On Thu, Nov 2, 2017 at 9:56 AM, Tyler Veinot <tylerkveinot at gmail.com> wrote:
> Andreas;
> Thanks for the reply; I knew there was a QGIS 3 in the works but I didn't
> think there was a 'working/usable' dev out, thanks for that. I am certainly
> going to install and play around with it.
> Tyler
> On Thu, Nov 2, 2017 at 9:17 AM, Andreas Neumann <a.neumann at carto.net>
> wrote:
>> Hi Tyler,
>> 3D visualization will be a core feature in QGIS 3.
>> If you want to play with 3D visualization, I recommend that you try/test
>> QGIS 3, even if it is still in bug fixing mode and not officially released.
>> You can either use the OSGeo4W installer and install the dev version or
>> use the weeklies (the newest one published at http://qgis.org/downloads/w
>> eekly/?C=M;O=D).
>> See also http://www.lutraconsulting.co.uk/blog/2017/10/16/buildi
>> ngs-in-qgis3d/ and https://twitter.com/lutraconsulting
>> Martin Dobias from Lutra is the main developer of the new 3D viz
>> functionality in QGIS 3.
>> Greetings,
>> Andreas
>> On 2017-11-02 13:02, Tyler Veinot wrote:
>> Hello;
>> Is anyone out there doing anything with building models in QGIS? I have
>> some sketchup buildings in DXF format I have been playing with in AutoCAD
>> and QGIS. Trying to find a way to bring them into QGIS for viewing in the
>> qgs2threejs plugin, but when I do I get a crash dump.
>> Tried a simple cube as well.
>> I can bring in Z aware dxf files and view them so I am wondering how big
>> of a step is it to go from there to simple building models? Is anyone
>> working in this direction that has some insights or thoughts to share?
>> Thanks;
>> Tyler
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171102/e2779c65/attachment.html>
