[Qgis-user] Building models in QGIS
Karl Magnus Jönsson
Karl-Magnus.Jonsson at kristianstad.se
Fri Nov 3 03:14:50 PDT 2017
Hi!
I'm playing around with the possibilities of 3D-building in the qgis2threejs-plug-in. You can use collada models, exportable from Sketchup, on point features in the plug-in. So I've made a point on the desired building, attached the model and a proper scaling. I've had some luck with it but think it will be hard to to for more than a few buildings at a time. Would be nice to hear if you make progress in either way.
/Karl-Magnus
2 nov. 2017 kl. 19:37 skrev Saber Razmjooei <saber.razmjooei at lutraconsulting.co.uk<mailto:saber.razmjooei at lutraconsulting.co.uk>>:
HI Tyler,
Did you try to enable 3d styling for your vectors (available from Style panel)?
No other dependcy is needed. The documentation for 3 is underway but you can refer to the links from Andreas' email.
Regards
Saber
On 2 Nov 2017 4:53 pm, "Tyler Veinot" <tylerkveinot at gmail.com<mailto:tylerkveinot at gmail.com>> wrote:
Andreas;
I installed the QGIS 2.99 and added some data, the 3D map seems to work well with grid/raster dems but it doesn't display XYZ/XYZM geometries based on the Z coordinate. I only did a basic install using the downloadable installer; is there other dependencies I should install or is it only for viewing rasters and DEM's in 3D?
Tyler
On Thu, Nov 2, 2017 at 9:56 AM, Tyler Veinot <tylerkveinot at gmail.com<mailto:tylerkveinot at gmail.com>> wrote:
Andreas;
Thanks for the reply; I knew there was a QGIS 3 in the works but I didn't think there was a 'working/usable' dev out, thanks for that. I am certainly going to install and play around with it.
Tyler
On Thu, Nov 2, 2017 at 9:17 AM, Andreas Neumann <a.neumann at carto.net<mailto:a.neumann at carto.net>> wrote:
Hi Tyler,
3D visualization will be a core feature in QGIS 3.
If you want to play with 3D visualization, I recommend that you try/test QGIS 3, even if it is still in bug fixing mode and not officially released.
You can either use the OSGeo4W installer and install the dev version or use the weeklies (the newest one published at http://qgis.org/downloads/weekly/?C=M;O=D).
See also http://www.lutraconsulting.co.uk/blog/2017/10/16/buildings-in-qgis3d/ and https://twitter.com/lutraconsulting
Martin Dobias from Lutra is the main developer of the new 3D viz functionality in QGIS 3.
Greetings,
Andreas
On 2017-11-02 13:02, Tyler Veinot wrote:
Hello;
Is anyone out there doing anything with building models in QGIS? I have some sketchup buildings in DXF format I have been playing with in AutoCAD and QGIS. Trying to find a way to bring them into QGIS for viewing in the qgs2threejs plugin, but when I do I get a crash dump.
Tried a simple cube as well.
I can bring in Z aware dxf files and view them so I am wondering how big of a step is it to go from there to simple building models? Is anyone working in this direction that has some insights or thoughts to share?
Thanks;
Tyler
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171103/fcdc6a80/attachment.html>
