[Qgis-user] Building models in QGIS
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Fri Nov 3 03:22:33 PDT 2017
Hi Karl,
QGIS native 3D already supports 3D models:
http://assimp.org/main_features_formats.html
See also:
https://twitter.com/AndiNeum/status/926035833358094336
For buildings, ideally you need to have them as 3D polygons (e.g. CityGML).
With the latest versions of GDAL/OGR you can convert them to a usable
format and render them as 3D in QGIS:
http://www.lutraconsulting.co.uk/blog/2017/10/16/buildings-in-qgis3d/
Regards
Saber
On 3 November 2017 at 10:14, Karl Magnus Jönsson <
Karl-Magnus.Jonsson at kristianstad.se> wrote:
> Hi!
> I’m playing around with the possibilities of 3D-building in the
> qgis2threejs-plug-in. You can use collada models, exportable from Sketchup,
> on point features in the plug-in. So I’ve made a point on the desired
> building, attached the model and a proper scaling. I’ve had some luck with
> it but think it will be hard to to for more than a few buildings at a time.
> Would be nice to hear if you make progress in either way.
> /Karl-Magnus
> 2 nov. 2017 kl. 19:37 skrev Saber Razmjooei <saber.razmjooei@
> lutraconsulting.co.uk>:
> HI Tyler,
> Did you try to enable 3d styling for your vectors (available from Style
> panel)?
> No other dependcy is needed. The documentation for 3 is underway but you
> can refer to the links from Andreas' email.
> Regards
> Saber
> On 2 Nov 2017 4:53 pm, "Tyler Veinot" <tylerkveinot at gmail.com> wrote:
> Andreas;
> I installed the QGIS 2.99 and added some data, the 3D map seems to work
> well with grid/raster dems but it doesn't display XYZ/XYZM geometries based
> on the Z coordinate. I only did a basic install using the downloadable
> installer; is there other dependencies I should install or is it only for
> viewing rasters and DEM's in 3D?
> Tyler
> On Thu, Nov 2, 2017 at 9:56 AM, Tyler Veinot <tylerkveinot at gmail.com>
> wrote:
>> Andreas;
>> Thanks for the reply; I knew there was a QGIS 3 in the works but I didn't
>> think there was a 'working/usable' dev out, thanks for that. I am certainly
>> going to install and play around with it.
>> Tyler
>> On Thu, Nov 2, 2017 at 9:17 AM, Andreas Neumann <a.neumann at carto.net>
>> wrote:
>>> Hi Tyler,
>>> 3D visualization will be a core feature in QGIS 3.
>>> If you want to play with 3D visualization, I recommend that you try/test
>>> QGIS 3, even if it is still in bug fixing mode and not officially released.
>>> You can either use the OSGeo4W installer and install the dev version or
>>> use the weeklies (the newest one published at
>>> http://qgis.org/downloads/weekly/?C=M;O=D).
>>> See also http://www.lutraconsulting.co.uk/blog/2017/10/16/buildi
>>> ngs-in-qgis3d/ and https://twitter.com/lutraconsulting
>>> Martin Dobias from Lutra is the main developer of the new 3D viz
>>> functionality in QGIS 3.
>>> Greetings,
>>> Andreas
>>> On 2017-11-02 13:02, Tyler Veinot wrote:
>>> Hello;
>>> Is anyone out there doing anything with building models in QGIS? I have
>>> some sketchup buildings in DXF format I have been playing with in AutoCAD
>>> and QGIS. Trying to find a way to bring them into QGIS for viewing in the
>>> qgs2threejs plugin, but when I do I get a crash dump.
>>> Tried a simple cube as well.
>>> I can bring in Z aware dxf files and view them so I am wondering how big
>>> of a step is it to go from there to simple building models? Is anyone
>>> working in this direction that has some insights or thoughts to share?
>>> Thanks;
>>> Tyler
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
Saber Razmjooei
+44 (0)7568 129733
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171103/6e93fe2b/attachment.html>
