[Qgis-user] Building models in QGIS
Tyler Veinot
tylerkveinot at gmail.com
Fri Nov 3 05:41:38 PDT 2017
COLLADA works brilliantly, I would like to try JSON as well. Mine didn't
have any texture to it, the model came in black don't know if textures are
not supported yet or if the model doesn't have one, will look into it
further. I have not tested this in the QGIS 3 beta yet but will soon.
DXF's of building models crash both QGIS systems. They came from Sketchup
but I used AutoCAD to simplify them a bit as well with no luck.
Have not gotten into the 3D polygon method yet either but will certainly
try further when time permits.
Tyler
On Fri, Nov 3, 2017 at 7:22 AM, Saber Razmjooei <
saber.razmjooei at lutraconsulting.co.uk> wrote:
> Hi Karl,
> QGIS native 3D already supports 3D models:
> http://assimp.org/main_features_formats.html
> See also:
> https://twitter.com/AndiNeum/status/926035833358094336
> For buildings, ideally you need to have them as 3D polygons (e.g.
> CityGML). With the latest versions of GDAL/OGR you can convert them to a
> usable format and render them as 3D in QGIS:
> http://www.lutraconsulting.co.uk/blog/2017/10/16/buildings-in-qgis3d/
> Regards
> Saber
> On 3 November 2017 at 10:14, Karl Magnus Jönsson <Karl-Magnus.Jonsson@
> kristianstad.se> wrote:
>> Hi!
>> I’m playing around with the possibilities of 3D-building in the
>> qgis2threejs-plug-in. You can use collada models, exportable from Sketchup,
>> on point features in the plug-in. So I’ve made a point on the desired
>> building, attached the model and a proper scaling. I’ve had some luck with
>> it but think it will be hard to to for more than a few buildings at a time.
>> Would be nice to hear if you make progress in either way.
>> /Karl-Magnus
>> 2 nov. 2017 kl. 19:37 skrev Saber Razmjooei <
>> saber.razmjooei at lutraconsulting.co.uk>:
>> HI Tyler,
>> Did you try to enable 3d styling for your vectors (available from Style
>> panel)?
>> No other dependcy is needed. The documentation for 3 is underway but you
>> can refer to the links from Andreas' email.
>> Regards
>> Saber
>> On 2 Nov 2017 4:53 pm, "Tyler Veinot" <tylerkveinot at gmail.com> wrote:
>> Andreas;
>> I installed the QGIS 2.99 and added some data, the 3D map seems to work
>> well with grid/raster dems but it doesn't display XYZ/XYZM geometries based
>> on the Z coordinate. I only did a basic install using the downloadable
>> installer; is there other dependencies I should install or is it only for
>> viewing rasters and DEM's in 3D?
>> Tyler
>> On Thu, Nov 2, 2017 at 9:56 AM, Tyler Veinot <tylerkveinot at gmail.com>
>> wrote:
>>> Andreas;
>>> Thanks for the reply; I knew there was a QGIS 3 in the works but I
>>> didn't think there was a 'working/usable' dev out, thanks for that. I am
>>> certainly going to install and play around with it.
>>> Tyler
>>> On Thu, Nov 2, 2017 at 9:17 AM, Andreas Neumann <a.neumann at carto.net>
>>> wrote:
>>>> Hi Tyler,
>>>> 3D visualization will be a core feature in QGIS 3.
>>>> If you want to play with 3D visualization, I recommend that you
>>>> try/test QGIS 3, even if it is still in bug fixing mode and not officially
>>>> released.
>>>> You can either use the OSGeo4W installer and install the dev version or
>>>> use the weeklies (the newest one published at
>>>> http://qgis.org/downloads/weekly/?C=M;O=D).
>>>> See also http://www.lutraconsulting.co.uk/blog/2017/10/16/buildi
>>>> ngs-in-qgis3d/ and https://twitter.com/lutraconsulting
>>>> Martin Dobias from Lutra is the main developer of the new 3D viz
>>>> functionality in QGIS 3.
>>>> Greetings,
>>>> Andreas
>>>> On 2017-11-02 13:02, Tyler Veinot wrote:
>>>> Hello;
>>>> Is anyone out there doing anything with building models in QGIS? I have
>>>> some sketchup buildings in DXF format I have been playing with in AutoCAD
>>>> and QGIS. Trying to find a way to bring them into QGIS for viewing in the
>>>> qgs2threejs plugin, but when I do I get a crash dump.
>>>> Tried a simple cube as well.
>>>> I can bring in Z aware dxf files and view them so I am wondering how
>>>> big of a step is it to go from there to simple building models? Is anyone
>>>> working in this direction that has some insights or thoughts to share?
>>>> Thanks;
>>>> Tyler
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
> Saber Razmjooei
> +44 (0)7568 129733 <+44%207568%20129733>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171103/7e26f1c8/attachment.html>
