[Qgis-user] Building models in QGIS
Tyler Veinot
tylerkveinot at gmail.com
Fri Nov 3 08:35:22 PDT 2017
All;
QGIS 3 is going to be awesome, well it is now, I just added my model to a
3D map as a model point and it looks pretty good. I used a number of
methods in COLLADA; no texture, texture, photo texture, edges, 2 sided
edges, etc.. they all seem to work. The only thing I will note is that the
Photo Textures are upside down on the faces.
As for the base data, I added a rasterized DEM but it doesn't seem to
display as 3D, it looks more like a flat hillshade.
Anyway this is a newer QGIS than what I am use too and still in Dev stages
so I am sure I am just overlooking something or if it is an issue it will
be fixed by release.
Anyway, this is great. Thanks for the help.
Tyler
On Fri, Nov 3, 2017 at 9:41 AM, Tyler Veinot <tylerkveinot at gmail.com> wrote:
> COLLADA works brilliantly, I would like to try JSON as well. Mine didn't
> have any texture to it, the model came in black don't know if textures are
> not supported yet or if the model doesn't have one, will look into it
> further. I have not tested this in the QGIS 3 beta yet but will soon.
> DXF's of building models crash both QGIS systems. They came from Sketchup
> but I used AutoCAD to simplify them a bit as well with no luck.
> Have not gotten into the 3D polygon method yet either but will certainly
> try further when time permits.
> Tyler
> On Fri, Nov 3, 2017 at 7:22 AM, Saber Razmjooei <saber.razmjooei@
> lutraconsulting.co.uk> wrote:
>> Hi Karl,
>> QGIS native 3D already supports 3D models:
>> http://assimp.org/main_features_formats.html
>> See also:
>> https://twitter.com/AndiNeum/status/926035833358094336
>> For buildings, ideally you need to have them as 3D polygons (e.g.
>> CityGML). With the latest versions of GDAL/OGR you can convert them to a
>> usable format and render them as 3D in QGIS:
>> http://www.lutraconsulting.co.uk/blog/2017/10/16/buildings-in-qgis3d/
>> Regards
>> Saber
>> On 3 November 2017 at 10:14, Karl Magnus Jönsson <
>> Karl-Magnus.Jonsson at kristianstad.se> wrote:
>>> Hi!
>>> I’m playing around with the possibilities of 3D-building in the
>>> qgis2threejs-plug-in. You can use collada models, exportable from Sketchup,
>>> on point features in the plug-in. So I’ve made a point on the desired
>>> building, attached the model and a proper scaling. I’ve had some luck with
>>> it but think it will be hard to to for more than a few buildings at a time.
>>> Would be nice to hear if you make progress in either way.
>>> /Karl-Magnus
>>> 2 nov. 2017 kl. 19:37 skrev Saber Razmjooei <
>>> saber.razmjooei at lutraconsulting.co.uk>:
>>> HI Tyler,
>>> Did you try to enable 3d styling for your vectors (available from Style
>>> panel)?
>>> No other dependcy is needed. The documentation for 3 is underway but you
>>> can refer to the links from Andreas' email.
>>> Regards
>>> Saber
>>> On 2 Nov 2017 4:53 pm, "Tyler Veinot" <tylerkveinot at gmail.com> wrote:
>>> Andreas;
>>> I installed the QGIS 2.99 and added some data, the 3D map seems to work
>>> well with grid/raster dems but it doesn't display XYZ/XYZM geometries based
>>> on the Z coordinate. I only did a basic install using the downloadable
>>> installer; is there other dependencies I should install or is it only for
>>> viewing rasters and DEM's in 3D?
>>> Tyler
>>> On Thu, Nov 2, 2017 at 9:56 AM, Tyler Veinot <tylerkveinot at gmail.com>
>>> wrote:
>>>> Andreas;
>>>> Thanks for the reply; I knew there was a QGIS 3 in the works but I
>>>> didn't think there was a 'working/usable' dev out, thanks for that. I am
>>>> certainly going to install and play around with it.
>>>> Tyler
>>>> On Thu, Nov 2, 2017 at 9:17 AM, Andreas Neumann <a.neumann at carto.net>
>>>> wrote:
>>>>> Hi Tyler,
>>>>> 3D visualization will be a core feature in QGIS 3.
>>>>> If you want to play with 3D visualization, I recommend that you
>>>>> try/test QGIS 3, even if it is still in bug fixing mode and not officially
>>>>> released.
>>>>> You can either use the OSGeo4W installer and install the dev version
>>>>> or use the weeklies (the newest one published at
>>>>> http://qgis.org/downloads/weekly/?C=M;O=D).
>>>>> See also http://www.lutraconsulting.co.uk/blog/2017/10/16/buildi
>>>>> ngs-in-qgis3d/ and https://twitter.com/lutraconsulting
>>>>> Martin Dobias from Lutra is the main developer of the new 3D viz
>>>>> functionality in QGIS 3.
>>>>> Greetings,
>>>>> Andreas
>>>>> On 2017-11-02 13:02, Tyler Veinot wrote:
>>>>> Hello;
>>>>> Is anyone out there doing anything with building models in QGIS? I
>>>>> have some sketchup buildings in DXF format I have been playing with in
>>>>> AutoCAD and QGIS. Trying to find a way to bring them into QGIS for viewing
>>>>> in the qgs2threejs plugin, but when I do I get a crash dump.
>>>>> Tried a simple cube as well.
>>>>> I can bring in Z aware dxf files and view them so I am wondering how
>>>>> big of a step is it to go from there to simple building models? Is anyone
>>>>> working in this direction that has some insights or thoughts to share?
>>>>> Thanks;
>>>>> Tyler
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Saber Razmjooei
>> +44 (0)7568 129733 <+44%207568%20129733>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171103/77074901/attachment.html>
