[Qgis-user] Python plugin is broken
    Tudorache, Marian
    Marian.Tudorache at navcanada.ca
    Thu Nov  9 08:14:44 PST 2017
Hola Juan,
Could you send the whole stack trace please?
There might be a dependency which causes the problem.
Thanks,
Marian
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Juan Jose Rodriguez
Sent: November-09-17 2:59 AM
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Python plugin is broken
I´m new to this support list, and would like to post a question.
I´m developing a QGIS Python plugin. The plugin loads in one computer but not in another (both with Windows 10). I get this message in the wrong one:
This plugin is broken
Error reading metadata: global name '__builtin__' is not defined
In the computer that gives the error message I have the latest QGIS version:
QGIS version
2.18.14
QGIS code revision
ff83b9a479
The one that runs OK has version 2.18.3
Any idea of what is happening?
Thanks
Juan Jose Rodriguez
FLO-2D Software  /  Hydronia LLC
www.flo-2d.com<http://www.flo-2d.com/>       www.hydronia.com<http://www.hydronia.com/>
jj at flo-2d.com<mailto:jj at flo-2d.com>
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171109/74b3877d/attachment.html>
