[Qgis-user] Python plugin is broken
Juan Jose Rodriguez jj at flo-2d.com
Thu Nov 9 18:00:37 PST 2017
Thanks.
I fixed the problem by deleting directory C:\OSGeo4W64, and reinstalling
QGIS version 2.18.14
Juan Jose Rodriguez
FLO-2D Software  /  Hydronia LLC
www.flo-2d.com       www.hydronia.com
jj at flo-2d.com
On Thu, Nov 9, 2017 at 12:14 PM, Tudorache, Marian <
Marian.Tudorache at navcanada.ca> wrote:
> Hola Juan,
> Could you send the whole stack trace please?
> There might be a dependency which causes the problem.
> Thanks,
> Marian
> *From:* Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *On Behalf
> Of *Juan Jose Rodriguez
> *Sent:* November-09-17 2:59 AM
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Python plugin is broken
> Hi,
> I´m new to this support list, and would like to post a question.
> I´m developing a QGIS Python plugin. The plugin loads in one computer but
> not in another (both with Windows 10). I get this message in the wrong one:
> *This plugin is broken*
> *Error reading metadata: global name '__builtin__' is not defined*
> In the computer that gives the error message I have the latest QGIS
> version:
> *QGIS version*
> *2.18.14*
> *QGIS code revision*
> *ff83b9a479*
> ​The one that runs OK has version 2.18.3
> ​Any idea of what is happening?
> Thanks
> Juan Jose Rodriguez
> jj at flo-2d.com
> This electronic message, as well as any transmitted files included in the
> electronic message, may contain privileged or confidential information and
> is intended solely for the use of the individual(s) or entity to which it
> is addressed. If you have received this electronic message in error please
> notify the sender immediately and delete the electronic message. Any
> unauthorized copying, disclosure or distribution of the electronic message
> is strictly forbidden. NAV CANADA accepts no liability for any damage
> caused by any virus and/or other malicious code transmitted by this
> electronic communication.
> Le présent message électronique et tout fichier qui peut y être joint
> peuvent contenir des renseignements privilégiés ou confidentiels destinés à
> l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si
> vous avez reçu ce message électronique par erreur, veuillez en informer
> l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation
> ou distribution du présent message électronique est strictement interdite.
> NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout
> virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171109/7bbef5af/attachment.html>
