[Qgis-user] Implement QGIS source
Richard Duivenvoorde
rdmailings at duif.net
Thu Nov 16 03:51:18 PST 2017
Hi Arun,
It is really better to address this kind of developer questions to the
QGIS-Developer list. This is the QGIS-User list, where most readers USE
qgis instead of Develop.
Regards,
On 16-11-17 12:49, Arun Bharathi wrote:
> Hi,
> I have compiled QGIS open source in visual studio 2013. But I am getting
> more errors and also I am not getting the meaning of the following
> sentence found in your help file (under section 4.1.3. Setting up the
> Visual Studio project with CMake).
> After the build completed you should install QGIS using the INSTALL target.
> Install QGIS by building the INSTALL project. By default this will
> install to c:\Program Files\qgis<version> (this can be changed by
> changing the CMAKE_INSTALL_PREFIX variable in cmake-gui).
> Thanks and Regards.
> P.Arun Bharathi
> On Wed, Nov 8, 2017 at 8:00 PM, Arun Bharathi <arunbharathimca at gmail.com
> <mailto:arunbharathimca at gmail.com>> wrote:
> Hi Marian,
> Yes. I need to build and execute QGIS open source in Qt windows.
> On Nov 8, 2017 7:36 PM, "Tudorache, Marian"
> <Marian.Tudorache at navcanada.ca
> <mailto:Marian.Tudorache at navcanada.ca>> wrote:
> Hi Arun,____
> __ __
> What does it mean to implement QGIS open source code in QT C++
> windows?____
> Does it mean to install QGIS in windows?____
> __ __
> Thanks,____
> marian____
> __ __
> *From:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org
> <mailto:qgis-user-bounces at lists.osgeo.org>] *On Behalf Of *Arun
> Bharathi
> *Sent:* November-08-17 7:14 AM
> *To:* qgis-user at lists.osgeo.org <mailto:qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] Implement QGIS source____
> __ __
> Hi,____
> I am new to QGIS open source software. I have adequate knowledge
> in Qt C++. I need to implement QGIS open source code in Qt C++
> windows. Plz help me.____
> ____
> Thanks and Regards.
> P.Arun Bharathi____
> __ __
> This electronic message, as well as any transmitted files
> included in the electronic message, may contain privileged or
> confidential information and is intended solely for the use of
> the individual(s) or entity to which it is addressed. If you
> have received this electronic message in error please notify the
> sender immediately and delete the electronic message. Any
> unauthorized copying, disclosure or distribution of the
> electronic message is strictly forbidden. NAV CANADA accepts no
> liability for any damage caused by any virus and/or other
> malicious code transmitted by this electronic communication.
> Le présent message électronique et tout fichier qui peut y être
> joint peuvent contenir des renseignements privilégiés ou
> confidentiels destinés à l’usage exclusif des personnes ou des
> organismes à qui ils s’adressent. Si vous avez reçu ce message
> électronique par erreur, veuillez en informer l’expéditeur
> immédiatement et supprimez le. Toute reproduction, divulgation
> ou distribution du présent message électronique est strictement
> interdite. NAV CANADA n’assume aucune responsabilité en cas de
> dommage causé par tout virus ou autre programme malveillant
> transmis par ce message électronique.
> Qgis-user mailing list
