[Qgis-user] Implement QGIS source
Tudorache, Marian
Marian.Tudorache at navcanada.ca
Thu Nov 16 07:44:47 PST 2017
I think it refers to run make install script which allows to deploy QGIS on your machine.
This is how I used to do in Linux.
If you want your QGIS in a windows machine why don`t use QGIS installers.
http://www.qgis.org/en/site/forusers/download.html
Thanks,
marian
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Arun Bharathi
Sent: November-16-17 6:49 AM
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Implement QGIS source
I have compiled QGIS open source in visual studio 2013. But I am getting more errors and also I am not getting the meaning of the following sentence found in your help file (under section 4.1.3. Setting up the Visual Studio project with CMake).
After the build completed you should install QGIS using the INSTALL target.
Install QGIS by building the INSTALL project. By default this will install to c:\Program Files\qgis<version> (this can be changed by changing the CMAKE_INSTALL_PREFIX variable in cmake-gui).
Thanks and Regards.
P.Arun Bharathi
On Wed, Nov 8, 2017 at 8:00 PM, Arun Bharathi <arunbharathimca at gmail.com<mailto:arunbharathimca at gmail.com>> wrote:
Hi Marian,
Yes. I need to build and execute QGIS open source in Qt windows.
On Nov 8, 2017 7:36 PM, "Tudorache, Marian" <Marian.Tudorache at navcanada.ca<mailto:Marian.Tudorache at navcanada.ca>> wrote:
Hi Arun,
What does it mean to implement QGIS open source code in QT C++ windows?
Does it mean to install QGIS in windows?
Thanks,
marian
From: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org<mailto:qgis-user-bounces at lists.osgeo.org>] On Behalf Of Arun Bharathi
Sent: November-08-17 7:14 AM
To: qgis-user at lists.osgeo.org<mailto:qgis-user at lists.osgeo.org>
Subject: [Qgis-user] Implement QGIS source
I am new to QGIS open source software. I have adequate knowledge in Qt C++. I need to implement QGIS open source code in Qt C++ windows. Plz help me.
Thanks and Regards.
P.Arun Bharathi
This electronic message, as well as any transmitted files included in the electronic message, may contain privileged or confidential information and is intended solely for the use of the individual(s) or entity to which it is addressed. If you have received this electronic message in error please notify the sender immediately and delete the electronic message. Any unauthorized copying, disclosure or distribution of the electronic message is strictly forbidden. NAV CANADA accepts no liability for any damage caused by any virus and/or other malicious code transmitted by this electronic communication.
Le présent message électronique et tout fichier qui peut y être joint peuvent contenir des renseignements privilégiés ou confidentiels destinés à l’usage exclusif des personnes ou des organismes à qui ils s’adressent. Si vous avez reçu ce message électronique par erreur, veuillez en informer l’expéditeur immédiatement et supprimez le. Toute reproduction, divulgation ou distribution du présent message électronique est strictement interdite. NAV CANADA n’assume aucune responsabilité en cas de dommage causé par tout virus ou autre programme malveillant transmis par ce message électronique.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20171116/1c3a51a1/attachment.html>
