[Qgis-user] ubuntugis: Broken after update to 2.18.14
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Fri Nov 24 08:14:27 PST 2017
update broke QGIS. Tested with ubuntugis-nigthly-release and ubuntugis on
Xenial.
Any ideas?
Cheers
Bernd
Reading package lists... Done
Building dependency tree
Reading state information... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
  python-qgis : Depends: python-qgis-common (=
1:2.18.14+24xenial-ubuntugis) but
1:2.18.14+git20171123+10b34b9+24xenial-ubuntugis is to be installed
                Depends: libqgis-analysis2.18.14 but it is not going to be
installed
                Depends: libqgis-server2.18.14 but it is not going to be
installed
  qgis : Depends: gdal-abi-2-2-1 but it is not installable
installed
         Depends: libqgis-app2.18.14 but it is not going to be installed
         Depends: qgis-providers (= 1:2.18.14+24xenial-ubuntugis) but
         Depends: qgis-common (= 1:2.18.14+24xenial-ubuntugis) but
         Recommends: qgis-plugin-globe but it is not going to be installed
  qgis-plugin-grass : Depends: qgis-plugin-grass-common (=
                      Depends: qgis-provider-grass (=
installed
E: Unable to correct problems, you have held broken packages.
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
