[Qgis-user] ubuntugis: Broken after update to 2.18.14
Angelos Tzotsos
gcpp.kalxas at gmail.com
Fri Nov 24 11:11:37 PST 2017
We updated GDAL in UbuntuGIS yesterday so QGIS packages need to rebuild.
Cheers,
Angelos
On 11/24/2017 06:14 PM, Bernd Vogelgesang wrote:
> Hi,
> update broke QGIS. Tested with ubuntugis-nigthly-release and ubuntugis
> on Xenial.
> Any ideas?
> Cheers
> Bernd
> Reading package lists... Done
> Building dependency tree
> Reading state information... Done
> Some packages could not be installed. This may mean that you have
> requested an impossible situation or if you are using the unstable
> distribution that some required packages have not yet been created
> or been moved out of Incoming.
> The following information may help to resolve the situation:
> The following packages have unmet dependencies:
> python-qgis : Depends: python-qgis-common (=
> 1:2.18.14+24xenial-ubuntugis) but
> 1:2.18.14+git20171123+10b34b9+24xenial-ubuntugis is to be installed
> Depends: libqgis-analysis2.18.14 but it is not going to
> be installed
> Depends: libqgis-server2.18.14 but it is not going to
> be installed
> qgis : Depends: gdal-abi-2-2-1 but it is not installable
> Depends: libqgis-analysis2.18.14 but it is not going to be
> installed
> Depends: libqgis-app2.18.14 but it is not going to be installed
> Depends: qgis-providers (= 1:2.18.14+24xenial-ubuntugis) but
> Depends: qgis-common (= 1:2.18.14+24xenial-ubuntugis) but
> Recommends: qgis-plugin-globe but it is not going to be installed
> qgis-plugin-grass : Depends: qgis-plugin-grass-common (=
> Depends: qgis-provider-grass (=
> to be installed
> E: Unable to correct problems, you have held broken packages.
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
