[Qgis-user] ubuntugis: Broken after update to 2.18.14
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Fri Nov 24 14:55:29 PST 2017
Am 24.11.2017, 20:11 Uhr, schrieb Angelos Tzotsos <gcpp.kalxas at gmail.com>:
> Hi,
> We updated GDAL in UbuntuGIS yesterday so QGIS packages need to rebuild.
> Cheers,
> Angelos
Hi Angelo,
is there any chance that you could synchronize your efforts a little bit?
It's really strange that shortly after the new QGIS point release, the
dependencies get changed.
If this would happen just once in a while, I wouldn't complain at all. But
this feels more like coordinated chaos ;)
Thanx for your work
Bernd
> On 11/24/2017 06:14 PM, Bernd Vogelgesang wrote:
>> Hi,
>> update broke QGIS. Tested with ubuntugis-nigthly-release and ubuntugis
>> on Xenial.
>> Any ideas?
>> Cheers
>> Bernd
>> Reading package lists... Done
>> Building dependency tree
>> Reading state information... Done
>> Some packages could not be installed. This may mean that you have
>> requested an impossible situation or if you are using the unstable
>> distribution that some required packages have not yet been created
>> or been moved out of Incoming.
>> The following information may help to resolve the situation:
>> The following packages have unmet dependencies:
>> python-qgis : Depends: python-qgis-common (=
>> 1:2.18.14+24xenial-ubuntugis) but
>> 1:2.18.14+git20171123+10b34b9+24xenial-ubuntugis is to be installed
>> Depends: libqgis-analysis2.18.14 but it is not going to
>> be installed
>> Depends: libqgis-server2.18.14 but it is not going to be
>> installed
>> qgis : Depends: gdal-abi-2-2-1 but it is not installable
>> Depends: libqgis-analysis2.18.14 but it is not going to be
>> installed
>> Depends: libqgis-app2.18.14 but it is not going to be installed
>> Depends: qgis-providers (= 1:2.18.14+24xenial-ubuntugis) but
>> Depends: qgis-common (= 1:2.18.14+24xenial-ubuntugis) but
>> Recommends: qgis-plugin-globe but it is not going to be
>> installed
>> qgis-plugin-grass : Depends: qgis-plugin-grass-common (=
>> Depends: qgis-provider-grass (=
>> be installed
>> E: Unable to correct problems, you have held broken packages.
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
