[Qgis-user] ubuntugis: Broken after update to 2.18.14
Angelos Tzotsos gcpp.kalxas at gmail.com
Sat Nov 25 03:14:07 PST 2017
Dear Bernd,
The transition of GDAL has been communicated in the UbuntuGIS mailing
list since Nov 7:
https://www.mail-archive.com/ubuntu@lists.osgeo.org/msg01406.html
Also, the hint that the maintenance team (volunteers) is trying to break
QGIS packages on purpose is totally unacceptable.
Angelos
On 11/25/2017 12:55 AM, Bernd Vogelgesang wrote:
> Am 24.11.2017, 20:11 Uhr, schrieb Angelos Tzotsos
> <gcpp.kalxas at gmail.com>:
>> Hi,
>> We updated GDAL in UbuntuGIS yesterday so QGIS packages need to rebuild.
>> Cheers,
>> Angelos
> Hi Angelo,
> is there any chance that you could synchronize your efforts a little bit?
> It's really strange that shortly after the new QGIS point release, the
> dependencies get changed.
> If this would happen just once in a while, I wouldn't complain at all.
> But this feels more like coordinated chaos ;)
> Thanx for your work
> Bernd
>> On 11/24/2017 06:14 PM, Bernd Vogelgesang wrote:
>>> Hi,
>>> update broke QGIS. Tested with ubuntugis-nigthly-release and
>>> ubuntugis on Xenial.
>>> Any ideas?
>>> Cheers
>>> Bernd
>>> Reading package lists... Done
>>> Building dependency tree
>>> Reading state information... Done
>>> Some packages could not be installed. This may mean that you have
>>> requested an impossible situation or if you are using the unstable
>>> distribution that some required packages have not yet been created
>>> or been moved out of Incoming.
>>> The following information may help to resolve the situation:
>>> The following packages have unmet dependencies:
>>>  python-qgis : Depends: python-qgis-common (=
>>> 1:2.18.14+24xenial-ubuntugis) but
>>> 1:2.18.14+git20171123+10b34b9+24xenial-ubuntugis is to be installed
>>>                Depends: libqgis-analysis2.18.14 but it is not going
>>> to be installed
>>>                Depends: libqgis-server2.18.14 but it is not going to
>>> be installed
>>>  qgis : Depends: gdal-abi-2-2-1 but it is not installable
>>>         Depends: libqgis-analysis2.18.14 but it is not going to be
>>> installed
>>>         Depends: libqgis-app2.18.14 but it is not going to be installed
>>>         Depends: qgis-providers (= 1:2.18.14+24xenial-ubuntugis) but
>>>         Depends: qgis-common (= 1:2.18.14+24xenial-ubuntugis) but
>>>         Recommends: qgis-plugin-globe but it is not going to be
>>> installed
>>>  qgis-plugin-grass : Depends: qgis-plugin-grass-common (=
>>>                      Depends: qgis-provider-grass (=
>>> to be installed
>>> E: Unable to correct problems, you have held broken packages.
Angelos Tzotsos, PhD
Charter Member
Open Source Geospatial Foundation
http://users.ntua.gr/tzotsos
