[Qgis-user] QGIS SVG: outdated warning
    Tobias Wendorff
    tobias.wendorff at tu-dortmund.de
    Sat Nov 25 00:44:10 PST 2017
Hi there!
I'm on latest QGIS2 (stable). When choosing "SVG export" on map composer,
you'll get this warning:
"The SVG export function in QGIS has several problems due to bugs and
deficiencies in the Qt4 svg code. In particular, there are problems with
layers not being clipped to the map bounding box.
If you require a vector-based output file from Qgis it is suggested that
you try printing to PostScript if the SVG output is not satisfactory."
QGIS2 uses QT5 and there's no PostScript export support anymore ;)
Shall I file this as a GUI bug?
Best regards,
Tobias
