[Qgis-user] QGIS SVG: outdated warning
    Matthias Kuhn
    matthias at opengis.ch
    Sat Nov 25 03:20:08 PST 2017
Hi Tobias,
there is no stable release using Qt5 so far. Can you verify with QGIS 2.99?
Thanks
Matthias
On 11/25/2017 09:44 AM, Tobias Wendorff wrote:
> Hi there!
> I'm on latest QGIS2 (stable). When choosing "SVG export" on map composer,
> you'll get this warning:
> "The SVG export function in QGIS has several problems due to bugs and
> deficiencies in the Qt4 svg code. In particular, there are problems with
> layers not being clipped to the map bounding box.
> If you require a vector-based output file from Qgis it is suggested that
> you try printing to PostScript if the SVG output is not satisfactory."
> QGIS2 uses QT5 and there's no PostScript export support anymore ;)
> Shall I file this as a GUI bug?
> Best regards,
> Tobias
> Qgis-user mailing list
