[Qgis-user] QGIS SVG: outdated warning
    Richard Duivenvoorde
    rdmailings at duif.net
    Sat Nov 25 03:31:23 PST 2017
I think Tobias was talking about 2.99. Just tested and msg is indeed
still there...
Both (svg and pdf) are working here with a simple colored shape with
labels with me.
Regards,
Richard
On 25-11-17 12:20, Matthias Kuhn wrote:
> Hi Tobias,
> there is no stable release using Qt5 so far. Can you verify with QGIS 2.99?
> Thanks
> Matthias
> On 11/25/2017 09:44 AM, Tobias Wendorff wrote:
>> Hi there!
>> I'm on latest QGIS2 (stable). When choosing "SVG export" on map composer,
>> you'll get this warning:
>> "The SVG export function in QGIS has several problems due to bugs and
>> deficiencies in the Qt4 svg code. In particular, there are problems with
>> layers not being clipped to the map bounding box.
>> If you require a vector-based output file from Qgis it is suggested that
>> you try printing to PostScript if the SVG output is not satisfactory."
>> QGIS2 uses QT5 and there's no PostScript export support anymore ;)
>> Shall I file this as a GUI bug?
>> Best regards,
>> Tobias
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
